Wilcox Gay Recorordio vs Meissner 9-1065
Romoorio
Post: # 43339Post Romoorio
Mon Jul 18, 2016 11:03 pm
Hey guys,
I'm researching these two lathes, both for sale near me (I think). I'm new to the cutting game and this will be my first lathe. I'm happy to use it as a project to get to learn cutting before upgrading.
I'm wondering about the pros and cons of each. Also, both machines are 110v whereas my power supply is 230v (New Zealand). How easy would it be to replace the motor? As I say, I'm happy to use this as a project.
Each will probably cost me around $500NZ ($350USD). Is this good value? Please remember NZ is in the middle of nowhere so most things are usually more expensive here.
Thanks for the help.
Romoorio
ArchaicRecords
Re: Wilcox Gay Recorordio vs Meissner 9-1065
Post: # 43518Post ArchaicRecords
Wed Aug 10, 2016 3:21 pm
Code: Select all
I only have experience with the Meissner.   It's difficult to get the cutting head to cut with nice clear signal. It seemed to work well once or twice after repairs, but after that the volume seems to be a bit too low, and you're taking a risk if you crank up the volume since at some point it can be burned out I believe.   Also, the lathe doesn't go far enough into the center, there's about an inch-and-a-half of disc space that goes unused (from the label out).  The lathe cuts at an angle more equivalent to a regular straight-arm tone-arm, not like the tangential (straight-across) cutting system like most lathes.
archaicrecords.com
Post: # 43520Post tragwag
Wed Aug 10, 2016 5:27 pm
I would honestly save your money. anything with a crystal cutting head will be a disappointment, even at it's best performance.
Having owned a recordette (I paid $65 for it, working) and a meissner (got it very cheaply, did minimal work),
they're really not all that useful to learn the standards of cutting on either.
the only scenario I would suggest the portable crystal cutters for, is cutting CDs or picnic plates on, on an experimental basis.
a Presto/Rek O Cut/Fairchild machine would be much more worth your time and investment.
these are setup much more like pro lathes, and the results can be quite good!
