305° Heissdampföl replacement
helmut erler
Post: # 63154Unread post helmut erler
Fri Jul 21, 2023 3:19 am
Hello all!
I am looking for a replacement of this oil "305° Heissdampföl" - used in the oil coupling of the Neumann turntable. Does anyone know a good replacement?
All the best wishes from Berlin, Helmut.
https://www.dropbox.com/scl/fi/xs46ewl1tcykywklhkl09/oil1.png?rlkey=83bekgyfll8yw5zk753oh9sci&dl=0
https://www.dropbox.com/scl/fi/l8oam9yxqa7lo7hqmkx83/oil2.jpg?rlkey=otj6hj6tm9lekjngym1x3h346&dl=0
dubcutter89
Re: 305° Heissdampföl replacement
Post: # 63155Unread post dubcutter89
Fri Jul 21, 2023 4:20 am
Dear Helmut!
Normally you should be able to recycle the oil in the coupler as it is not really lubricating and doing nothing special.
It is rather used as a rough lowpassfilter/damper for filtering out the noise from the lyrec motor...
Unfortunately I also lost the can with the sticky stuff from my last turntable disassembly so I need some too...
Had a quick look and found this stuff:
https://www.regner-dampftechnik.com/product-page/hei%C3%9Fdampf%C3%B6l-hei%C3%9Fdampfzylinder%C3%B6l
"Für echtes Heißdampföl gibt es keine Alternative." - für die kleine Dampf-Modelleisenbahn und große Lackfolienschneidetische?
Evtl. sollte man nachfragen ob es zäh wie Honig ist bevor man bestellt?
Oder für den Skipper auf dem Containerschiff:
https://laemmle-chemicals.ch/de_ch/products/automotiv/schiff/dampfzylinderoele.php
Denke je höher die Viskosität umso besser?
Lukas
flozki
Post: # 63159Unread post flozki
Sun Jul 23, 2023 7:30 am
Replace your lyrec and all is fine….:)
I would go with the thickest gear oil for Oldtimers
Or maybe fill it with some Polyurethane or silicone 2k
Material...
No more oil mess . this is 1920 technology and I guess we have some possibilities hundred years later
Also a good time to think about modern couplers instead of rubber disks
Then the 50/100 hz problematic is less
helmut erler
Post: # 63178Unread post helmut erler
Fri Jul 28, 2023 2:40 pm
yeah! thank you for the info!
