Re: Presto 6N guidance suggestions? (piecing together)
awesome!
I've got the presto R-27 tape machine with A920 amp.
Can't wait to get it up and running.
The A920, is that the single channel mixer/preamp? Does it have a balanced or unbalanced output?
Tim
MBL
Tim
MBL
Finally, it's here...
Its gonna need work. A bunch, but at least I have it.
Tim
MBL
Tim
MBL
Would one of you trolls out there with a 6N mind lifting your platter and taking detailed pictures of the motor mounting? I am missing the motor mount bracket and will need to fashion one. Measurements would also be very helpful!
Thanks for your continued help!
Tim
MBL
Tim
MBL
Ok so the more I look, I think this the right motor, but I don't have the mounting bracketry.
Anybody got some good pics of theirs? I think it says 1/25 hp and 1500/1800 rpm.
I mostly assembled an overhead here. I think I have it correct.
Tim
MBL
Tim
MBL
looks great!
I'll try to take some pictures of the motor in place, I'm doing some tuning on it anyway
So what are folks using for a turntable mat? Anybody seel these already cut?
Tim
MBL
Tim
MBL
Hello i have pictures of the motor mount in this topic about the speed problem i had awhile back.
http://lathetrolls.com/viewtopic.php?f=1&t=3738&hilit=Presto+motor+speed&sid=1eaa3be8108fb7f0b33cacef38838d06#p25125
The picture is half way down in the thread
Thanks for the pic! It'd be great if I could bave something like that CNC'd.
Hmm?
Tim
MBL
Hmm?
Tim
MBL
Any chance you could take some pics with a ruler against the bracket parts from various angles? I would like to find out the height of the risers the are on the motor bracket itself...and perhaps the table bracket as well. And I guess how far the curve extends from the flat parts on the ends. I actually have access to a tracing of the motor bracket but not the one that is fastened to the table.
Thanks again!
Tim
MBL
Thanks again!
Tim
MBL
So I keep on tinkering and tinkering. I want to get a proper switch for this table. I have a On-Off-On switch I bought, but not only is it not able to be adjusted to allow the proper amount of travel, it occured to me that it should be a momentary switch...otherwise it wouldn't automatically snap back when you moved to the middle selection unlest you did it manually.
I realize a push button switch was used as well as a toggle. Has anyone found a decent replacement switch that works as originally intended?
Thanks
Tim
MBL
Thanks
Tim
MBL
What are all of you using for monitors? How about monitor headphones? I pulled these old tweed monitors out of the attic, but have not yet decided how to best use them.
How does everyone here drive their monitor system? Do you use a separate PA amp?
Tim
MBL
Tim
MBL
Still working and collecting. I managed to get this Collins 212A-1 Broadcast console. Gonna need some work. Missing one big knob and some buttons. Anybody out there have parts for these?
Tim
MBL
Tim
MBL
- Angus McCarthy
Once again, it seems I am in the presence of equipment porn.
That console is a beaut. It's a dream of mine to piece together an analogue studio from roughly that era. Nice find.
I managed to find the correct meters as a pair...and the missing knob was actually stuffed inside the console. I still need a handle and some of those little buttons.
Tim
MBL
Ok, so a little developement. I managed to get another Presto 6N table and lathe together. This one has the 190-A equalizer and rack mounted companion switch.
And I'm gonna permanently mount a 6N overhead to the Micro Engineering transcription table.
Got my work cut out for me.
Tim
MBL
Tim
MBL
