What is the point of Polycarbonate Discs?
KeeLeh21
Post: # 15137Unread post KeeLeh21
Thu May 26, 2011 7:48 pm
What is the point of a polycarbonate disk? does anybody use those here?
Post: # 15151Unread post piaptk
Fri May 27, 2011 5:17 pm
Lasts longer and costs less than a lacquer. Can be cut into odd shapes, can be turned into picture discs.
They are really the only financially viable way to do runs of lathe cuts that still sound decent.
Post: # 15152Unread post opcode66
Fri May 27, 2011 5:51 pm
They are like one-off records.
Pros: Durability, can be queued up many times without degradation of the groove unlike a lacquer, can be played thousands of times not hundreds of time like a lacquer, are close to the weight and feal like pressed vinyl.
Cons: They are close to the cost of a lacquer (12" about $8 vs 11 for a lacquer), they have some amount of background noise not present in a lacquer, they are very staticy and will attract a lot of dust (even more than pressed vinyl), they are sort of a pain in the arse to cut right, a diamond stylus is required and is very expensive and can go bad quickly and esily.
dietrich10
Post: # 15153Unread post dietrich10
Fri May 27, 2011 6:57 pm
we can get price lower than $8
cutting lacquers-vms70 system
maniman
Post: # 15154Unread post maniman
Fri May 27, 2011 7:20 pm
piaptk wrote: They are really the only financially viable way to do runs of lathe cuts that still sound decent.
Amen.
Thinking a bit more about the clarification of the sound difference between , with the Shank stylus now can cut poly with the most cutterheads , not ?
how really sounds a good serious lathe cutting with a diamond ? ( on Neumann or similar for example ).
In other words
Talking about a serious lathe (like a Neumann), we can compare the traditional lacquer cut (with the appropriate stylus ) with the same machine cutting poly with a diamond in terms of sound quality ?
That limitation is inherent to the materials and the extra hardness , or are more lathe quality related ? guess many many other differences between the machine that usually cut lacquers and the one(s?) that cut poly (in all terms , precision , costs , etc )
Someday , someday hope can try by myself.
KeeLeh21
Post: # 15155Unread post KeeLeh21
Fri May 27, 2011 9:20 pm
opcode66 wrote:They are like one-off records.
thanks very helpful post
Post: # 15158Unread post opcode66
Sat May 28, 2011 12:24 am
Good results are possible with some work. I hope I didn't deter you from trying to cut plastic. Everything is a give and take you know.
maniman
Post: # 15166Unread post maniman
Mon May 30, 2011 5:30 am
Aha , I can't imagine , I only saw a Neumann a years ago , never touch one , If I'm not wrong the Nickou's one is the only Neumann alive in the city.
Maybe seems and stupid idea but modding a Neumann to cut poly can mean the best durable dub ever seen , and can give new life to a Neumann, in the sense of how many weekly cuts have to do to make it profitable , not ? I imagine the master recording business are relatively limited , the pressed production are far far away of the good times , not ?
In all sizes plant ( from relatively small as my45 until giants as GZ media ) the lathe use is relatively necessary , but have a serious lathe that isnt part of a pressing chain seems me totally non-viable , Now knowing this maybe can think in that as very very long term project.
Post: # 15171Unread post opcode66
Mon May 30, 2011 6:40 pm
I didn't have to mod anything. Just used a diamond instead of a sapphire. And, had a lamp with a 100W incandescent bulb pointed at the surface of the disc. Let the disc heat up. When it is at optimal temperature start cutting.
ArchaicRecords
Post: # 15186Unread post ArchaicRecords
Wed Jun 01, 2011 3:43 pm
Isn't it possible to cut into poly with a heated steel stylus?
archaicrecords.com
