dd turntable 1 kgf/cm of torque
Hello to all, I have a question to propose here : a direct drive turntable as for example an American Audio TTD 2400 from 1 kgf/cm of torque or more could be enough for cutting or no ?
Is there someone here that cut with a turntable with this torque ?
Thanks to all.
Cheers.
Thanks to all.
Cheers.
I don't know if this is enough torque, but for comparison, the old Presto 6N has a 1/25 HP Bodine synchronous motor. If you do the math, at 33 RPM this equates to about 87 Kg-cm of torque. There is probably a good deal of loss from the motor shaft to turntable platter and there is a large amount power needed to drive the overhead mechanism, but it gives you some idea of the requirements. In the case of a direct drive, you may be able to get away with much less since there is a servo in operation and if the head advance is done by an external drive motor, you may be ok. I susupect if you are just planning to cut laquers, you should be fine. If you want more torque in a cheap TT, the Newmark TT200 specs 1.7Kg-cm of torque.
No laquers, I must start to do experiments possibly with polycarbonate, or other similar material with my Poltz Freres that I have restored in this last month.
I don't know if you know as has built a Poltz, but is similar a Rek o Kut M12S, only the mechanism has moved by a belt under the plate.
Yes, then I am thinking to insert another motor for move the head advance, but I am dubios about a question : is necessary that this second motor must be in sync with the direct drive motor, or no ?
Thanks.
Thanks.
There is no need to have the motor(s) in sync. In fact, having the head advance separated from the platter motor is a plus. It allows you to easily change the groove pitch of your cuts. When using a Presto 6N and similar units, you have to change feedscrews to accomplish this. With a separate drive for the head, you just change the motor speed and you get variable pitch. You could implement a real-time variable pitch system in the future with a setup like this.
overhead feed accuracy
Mark,
is the speed accuracy of motor for overhead feed as critical as that of the turntable speed accuracy?
emidisc
emidisc
Absolutely NO , the Autogroove , Ptich Boxes , Auto Distancers are the demostration , the advance speed didnt have any effect on the audio (unless a modulated groove reaches the groove before) , in that systems the advance speed it's changed continuously and no heard effect about. not sirs?
About that low torque , in the VR the carriage advance don't depend of the TT torque , coz of that can cut with 1,2 Kg/cm2 , the VC 200 seems works pretty good with the Technics , maybe some users here can give more details , recently I gift an M12 overhead to a friend that is starting in cutting , the Technics can move the carriage without strobe movings , but maybe when have a stylus the things change , if you have the TT , simply , TEST IT.
