Presto 6N guidance suggestions? (piecing together)
JayDC
Re: Presto 6N guidance suggestions? (piecing together)
Post: # 23101Unread post JayDC
Mon Feb 04, 2013 8:39 am
I have a fully fictional 6n turntable that I do not use.. Not sure if I'm ready to part with it, but if you're interested shoot me an offer, and we'll see what we can do..
JayDC
Post: # 23108Unread post JayDC
Mon Feb 04, 2013 11:31 am
hahahaa!!! functional.. dumb auto-correct..
MBL
Post: # 23110Unread post MBL
Mon Feb 04, 2013 12:25 pm
PM sent. :P
Tim
MBL
Post: # 23113Unread post piaptk
Mon Feb 04, 2013 1:50 pm
If your head is working, i would not recommend getting it rewound right now. Both Len H and Gib are having major problems... I own 8 heads and only one is working. The other 7 are spread out between Len and Gib and they are having a lot of problems getting them working... So, keep it until they figure out what is going on...
powerstrip
Post: # 23138Unread post powerstrip
Tue Feb 05, 2013 1:39 am
piaptk wrote:If your head is working, i would not recommend getting it rewound right now. Both Len H and Gib are having major problems... I own 8 heads and only one is working. The other 7 are spread out between Len and Gib and they are having a lot of problems getting them working... So, keep it until they figure out what is going on...
....so in a nice way ....pssst... get in the back of the line!! ;)
powerstrip
Post: # 23139Unread post powerstrip
Tue Feb 05, 2013 1:44 am
Honestly a lil late after jay stepped up and offered, but.
Most the performance of that 6N seems to be in that overhead mechanism, I could see the turntable being quieter through another setup.
It is easier just to match them up, and, you will have to very precisely drill/tap your hole through a chassis if you are planning a mix 'frankenlathe', but once you have those overheads, you are getting pretty close to the ballpark, you just need a decent transcription table and some serious machining.
Just my thought on three overheads with no platter
MBL
Post: # 23245Unread post MBL
Sat Feb 09, 2013 10:03 pm
Haven't yet heard back from Jay with particulars, but I think I will try and get a proper Presto table. I kinda don't want to frankenlathe it...although, I know that it is a viable option.
Tim
MBL
MBL
Post: # 24448Unread post MBL
Sun Mar 31, 2013 5:52 pm
So I may have the table problem resolved?! Crossing fingers still. But now I have a question about tonearms. What I seem to notice as typical on a 6N is the Audax brand. Now there is surely a pecking order of quality. Can anyone make some suggestions on a model to look for?
Thanks
Tim
MBL
MBL
Post: # 24449Unread post MBL
Sun Mar 31, 2013 6:26 pm
Oh and while I'm asking, anyone know what kind of cutterhead is on this overhead assembly?
Tim
MBL
Angus McCarthy
Post: # 24451Unread post Angus McCarthy
Sun Mar 31, 2013 9:45 pm
I can't say I've ever seen one like that connected to a 6N overhead - it looks like it has an extra mounting bracket added. Are there no identifying marks at all?
It does look somewhat similar to the early Western Electric field-coil Vitaphone cutter, minus the long dampening shaft. Maybe a close cousin?
MBL
Post: # 24452Unread post MBL
Sun Mar 31, 2013 10:04 pm
Is there such a thing as an Olsen head? I think I remember someone saying something about an Olsen. I'll have to pull it off to see if there is any kind of name. Makes you wonder why someone would go through the trouble when a presto head would fit right on.
Tim
MBL
Post: # 24484Unread post tragwag
Mon Apr 01, 2013 4:24 pm
from what I've heard that is an Olsen head.
please correct me if I'm wrong, but I've heard Len Horowitz say he first used that head with a presto setup when he started.
I've seen a couple of those, and they have no identifying markings from what I can tell
Angus McCarthy
Post: # 24489Unread post Angus McCarthy
Mon Apr 01, 2013 5:05 pm
In that case, pic definitely saved for reference!
MBL
Post: # 24493Unread post MBL
Mon Apr 01, 2013 6:55 pm
Here are some pics. Now Does anyone know anything about an Olsen head? And why would you go through so much trouble getting it to fit? It is on there with some precision. This one is marked 500 ohms...in the middle No.5 is on the right and SER.C is on the left. Ideas?
Angus McCarthy
Post: # 24497Unread post Angus McCarthy
Mon Apr 01, 2013 9:57 pm
I'm willing to bet that the design points to an early date. It would explain having to add the special mounting bracket. It's awfully chunky, and again bears a resemblance to the early WE cutters:
(why did I not save the pictures from that auction!?)
Post: # 24508Unread post tragwag
Tue Apr 02, 2013 11:51 am
we have one here at Complete Mastering,
I believe it's from Al Grundy's place.
The most identifiable characteristic of the head, is it's weight.
It's a good 1/2 LB or 8 oz
Very solid feeling.
It has, on both sides, a little viewing area to see if the stylus is set correctly.
The holder seems to fit a smaller stylus than the Capps long shank I use with the Presto 1-C and 1-D heads.
But there also seem to be other adjustments on the sides that I can't budge at the moment.
here's some pictures, sorry they're from my phone:
http://i174.photobucket.com/albums/w111/insidejoke121202/0402131142_zpsb2e5059c.jpg
http://i174.photobucket.com/albums/w111/insidejoke121202/0402131143b_zps443ced8f.jpg
http://i174.photobucket.com/albums/w111/insidejoke121202/0402131143_zpsfb4d8a00.jpg
http://i174.photobucket.com/albums/w111/insidejoke121202/0402131143c_zps09a21a27.jpg
http://i174.photobucket.com/albums/w111/insidejoke121202/0402131144_zps165b3dc9.jpg
MBL
Post: # 24509Unread post MBL
Tue Apr 02, 2013 12:28 pm
Yup. That's the one. Any info available as to when they were made or how good they are?
Tim
MBL
MBL
Post: # 24533Unread post MBL
Thu Apr 04, 2013 8:30 am
So I picked up an Audak/Audax AT-12 tone arm. Any thoughts on these? What do all you folks use for tone arms?
Tim
MBL
MBL
Post: # 25885Unread post MBL
Mon Jun 10, 2013 11:56 am
So here's a little update, I got some more Presto reel equipment in a second tower.
And in the not counting your chickens before they're hatched category...I may have my turntable situation solved. More to come on that later.
Not pictured in the new tower is that I have put in an Ampex 601 preamp and reel and an extra Ampex 600 preamp. The light on the bottom, is from a 1930's Steam Locomotive, and not for use in the studio...yet. :lol:
Tim
MBL
