IRIAA huh?
- uvoscillator
IRIAA huh?
Dear list,
Just found this on local market, can it be used for cutting ?
This is unit for testing RIAA circuits.
https://www.avito.ru/moskva/audio_i_video/prodayu_emt_157_inverse_riaa_dlya_fonokorrektorov_529117931
Some info on P.42
http://lcweb2.loc.gov/master/mbrs/recording_preservation/manuals/EMT%20General%20Catalog%20(June%201968).pdf
Thanks !
S
Some info on P.42
Thanks !
S
Best !
Re: IRIAA huh?
The second link is broken so it's hard to see the specs, however looking at it it seems to be a proper "plug in" so as to provide the reverse RIAA curve which is a requirement for cutting a record since the amplification equipment with a phono input will add the the curve back
It seems to also have a few options, as a guess looks like it was made before the standard curve was adopted by all and sundry
If it is in working order and at a reasonable cost it will be useful for a semi pro use as most cutting lathes do have the inverse curve built in to the system
- uvoscillator
Re: IRIAA huh?
thanks for the input !mossboss wrote:The second link is broken so it's hard to see the specs, however looking at it it seems to be a proper "plug in" so as to provide the reverse RIAA curve which is a requirement for cutting a record since the amplification equipment with a phono input will add the the curve back
owner wants crazy 450EUR, but we can have trade though
here is nice booklet with some words on P.42
https://drive.google.com/file/d/0B7-V3HakD41BVThWRFR5blp2aXM/view?usp=sharing
do you think it can handle two channels for stereo IRIAA ?
thanks !
Best !
- dubcutter89
Re: IRIAA huh?
Hi!
Haven't read the brochure, but the only EMT IRIAA thing I know is just a passive unit - 3 resistors and 2 capacitors will do the same...
Lukas
Lukas
- uvoscillator
Re: IRIAA huh?
thanks Lucas, expensive resistors though ))dubcutter89 wrote:Hi!
Lukas
Best !
- dubcutter89
Re: IRIAA huh?
Yup, resistors and caps seem to be quiet expensive these days:
http://lathetrolls.com/viewtopic.php?f=4&t=5875&hilit=riaa+passive
60$ for 3 resistors and 2 caps? still too much for me...
