vanrock cutter for repair
luke13
Post: # 43657Unread post luke13
Tue Aug 23, 2016 2:19 am
I have a problem with a recorder vanrock recently bought, looking for someone who can help me or knows where I can repair the car.
Problem: during the "recording" does not advance horizontally while standing, ending work. It 'happened suddenly after having tested and made two discs (wow ...). I think it is a mechanical problem or something or because the other positions all work. Thanks in advance to anyone who can help me. :( :(
studiorp
Re: vanrock cutter for repair
Post: # 43658Unread post studiorp
Tue Aug 23, 2016 3:17 am
Hello, probably you must change the belt oring below the machine, on the red pulley.
See the pics of another old post :
Check too if there are other belts, but I don't believe...
luke13
Post: # 43660Unread post luke13
Tue Aug 23, 2016 5:07 am
Many thanks for reply, today I will tray to open and look it, thanks again man!
luke13
Post: # 43668Unread post luke13
Tue Aug 23, 2016 1:26 pm
Probably I have another version with 2 belt oring on the right side...I can try to change it but where i can find it? Thanks
Soulbear
Post: # 43669Unread post Soulbear
Tue Aug 23, 2016 2:22 pm
Hi Luke13,
You may get lucky with a belt from a Power Transmission Supplier. Some will make a belt to order like this company who recently made up a Non-Standard Sized Polyurethane Belt for me :- http://www.motionco.co.uk/index.php?route=product/round_belt As an alternative, you could source some round Polyurethane Belting of either 3mm or 6mm, and have a go at jointing it yourself like this fellow does :- https://www.youtube.com/watch?v=FmrxY2l2mn0 Hope this helps. :wink: :P :D Soulbear
studiorp
Post: # 43670Unread post studiorp
This isn't a problem, you can find orings in ball bearing shops. Are two orings with circular section ?
luke13
Post: # 43671Unread post luke13
Tue Aug 23, 2016 2:33 pm
no are triangular section, thanks for help lathe rollers friends!
Soulbear
Post: # 43672Unread post Soulbear
Tue Aug 23, 2016 2:46 pm
Hi Luke13,
You still may be able to substitute a "Round" belt for a "V" belt if you chose the closest diameter to the "V" profile in the Pulley.
Provided that the application is not Life-threatening (Like Powering a Lift, or Elevator as our U.S. cousins call them) you should still be OK :wink: :P :D Regards Soulbear
studiorp
Post: # 43673Unread post studiorp
Tue Aug 23, 2016 3:11 pm
Triangular section ? Are you sure ? No square ?
Triang. section belts were used in the past in Uher reel to reel recorders. Unfortunately I haven't seen in shops. Perhaps somewhere in web... I think that were specialized products...
luke13
Post: # 43725Unread post luke13
Mon Aug 29, 2016 4:19 am
Sorry I write an error, are square...
studiorp
Post: # 43726Unread post studiorp
Mon Aug 29, 2016 5:00 am
I was sure that were square your belts...
So you can use square vhs recorder belts. These are more strong than a normal cassette deck square belts. You can find these in a electronic shop.
luke13
Post: # 44031Unread post luke13
Sun Sep 18, 2016 6:20 am
bad news. I changed two types of belts to the problem remains the same: standing in the car moves horizontally, then f.forward cre the input groove recording but when I switch the machine remains firm and continues to affect orizzontalemente without moving, then ending everything works again and creates the output groove. It is probably something more serious, perhaps the sensor that does not give the input or do not know what.
studiorp
Post: # 44034Unread post studiorp
Sun Sep 18, 2016 10:43 am
Hmm, try look if the gears are not grease sticked . Perhaps your machine after 35-40 years must be re-lubed in some parts...
luke13
Post: # 44158Unread post luke13
Thu Sep 29, 2016 1:55 am
I check all the machine and probably the problem is the sensor that give the imput to the machine to move horizontal movement when select the recording option. I think is this because when you select other options ( standing, fast forward and recording) is all ok,the machine moved without problems, if you select recording the machine remain in a fix position. But where i can find a sensor, 30-40 years old used in Japan, in Europe? I know there is a lot of these little machines ( also har m180) in Japan, used for a lot of time in Karaoke bars. Is possible that in Japan there is some people that can repair it.
studiorp
Post: # 44168Unread post studiorp
Thu Sep 29, 2016 10:27 am
This sensor is optoelectronic ?
discosdecorte
Post: # 53555Unread post discosdecorte
Mon Jul 01, 2019 8:43 am
studiorp wrote:Hmm, try look if the gears are not grease sticked . Perhaps your machine after 35-40 years must be re-lubed in some parts...
Hi!
I want to apply new grease in my Atom A101. Should I remove the old grease? How? Any grease brand/type recommendation?
Best regards,
Fer
๐Ÿ„ณ๐Ÿ„ธ๐Ÿ…‚๐Ÿ„ฒ๐Ÿ„พ๐Ÿ…‚ ๐Ÿ„ณ๐Ÿ„ด ๐Ÿ„ฒ๐Ÿ„พ๐Ÿ…๐Ÿ…ƒ๐Ÿ„ด
boryo
Post: # 53556Unread post boryo
Mon Jul 01, 2019 9:41 am
Hello,
As suggested here it is not recommended to use grease: https://agnewanalog.com/blog/2019/06/22/presto-75a-restoration-project/
Maybe do some more research to be 100% sure that you do it right.
Best,
Bob
discosdecorte
Post: # 53626Unread post discosdecorte
Thu Jul 11, 2019 5:34 pm
Mmmm I see... It does have grease in some mechanical parts, so I thought It could be the adequate product to re-apply, but now I'm not sure :)
Thanks for the info!
discosdecorte
Post: # 54237Unread post discosdecorte
Sat Oct 05, 2019 1:58 pm
FYI I've finally cleaned the old grease and then applied lithium grease. I've also applied a drop of sewing machine oil in some noisy pulleys. Seems to work better now!
