Greasing the platter shaft
- Soniphone Records
I've got a slight knocking that does not occur upon every rotation of the platter, but when it occurs it can be heard through playback. I pulled the ball bearing out of the shaft that the platter sits in and it looks ok, but I think my issue is that I need to add more lubrication.
Do I use the same oil that I used for lubricating the capstan motor?
- Aussie0zborn
Re: Greasing the platter shaft
Might be best to specify which unit you're talking about.
- fredbissnette
if you are just lubing the platter shaft bearing 3in1 works or gun oil or sewingmachine oil, you only need a drop
I had the same probleme with the mastering plate of souri.... I felt something knocking very smoothly ..... I just replaced the big heavy plate on my turntable.... just moved it a little bit and readjust it... and voila... it stopped, it's been more than a year now.
good luck
good luck
