Rek-o-Kut Arm from Ebay
Fabougino
Post: # 45472Unread post Fabougino
Sat Jan 07, 2017 6:39 am
Hello,
It's my first post after a small introduction in newbi post.
I am between build from scratch and find a "ready to cut system"
So it's a newbi question :
You've seen probably on Ebay the Rek-o-kut arm for 600$ and I would like to know :
If I make a support and using it directly on my direct drive turntable, It should work and move or I need more parts to use this "arm"
Thank all and have a good week-end,
Fabougino
Envoyé de mon iPhone en utilisant Tapatalk
Fabougino
Re: Rek-o-Kut Arm from Ebay
Post: # 45478Unread post Fabougino
Sat Jan 07, 2017 9:47 am
The link : https://www.ebay.com/itm/282303594811
mratx
Post: # 45480Unread post mratx
Sat Jan 07, 2017 11:47 am
You will of course need a cutter head, stylus, amp, etc. But for just the mechanics of the arm, the issues are going to be 1) the overhead requires a second turntable stud to rotate it correctly, so you would need to make some sort of modification for that purpose, and 2) does your turntable have enough torque to maintain correct speed while also driving the overhead? You have to have a high torque turntable of some type, if you search the site you'll find quite a few threads regarding the issue.
lofiaudio
Post: # 45481Unread post lofiaudio
Sat Jan 07, 2017 12:12 pm
Just want to say I purchased the previous identical arm the same seller had up a couple of months ago, and he did a wonderful job restoring the arm to it's full functioning glory. The arm is fully lubricated and worked like a charm right out of the box.
He also offered me this one and said it was freshly painted and refinished but I was impatient to get it shipped so I got the other one. Great seller.
Also I am successfully using mine without any sort of second stud on the platter. Using a much beefier turntable than a 1200 but it is working just fine with just the weight of the arm and the single stud in the center of the platter. Go for it!!
Fabougino
Post: # 45487Unread post Fabougino
Sun Jan 08, 2017 5:43 am
Hello,
Thank you for your two feedback.
I own for this project an Gimini 500 XL II with 1.2kgf.
Do I need a Special Amp or a regular audio amp is ok ?
I will try to find a cutting head ...
Thanks again and have a good day.
Fabougino
Post: # 45488Unread post Fabougino
Sun Jan 08, 2017 5:46 am
Also lofiaudio do you have a pic of you turntable with the Arm?
lofiaudio
Post: # 45501Unread post lofiaudio
Sun Jan 08, 2017 10:52 am
Regular (modern) power amp or decently powered receiver is fine if you get a head that is wound for 8 ohms. Depends on the head. Don't know about that turntable but you could try it out and look at getting something bigger like a technics sp-10 if it isn't sufficient.
Here is a picture of my Rek o Kut:
Fabougino
Post: # 45503Unread post Fabougino
Sun Jan 08, 2017 2:36 pm
Ok, it's a good point.
Your setup look good !!!
