Vinylrecorder T560 compatible turntables
yano
Post: # 45758Unread post yano
Tue Jan 24, 2017 1:17 pm
Hi Trolls !
Souri says Vinylrecorder compatible only Technics SL-1200 or 1210 !
Which might be good for? e.g. Pioneer PLX-1000 , Stanton ST-150, Reloop RP8000 etc. ?
TheCrates
Re: Vinylrecorder T560 compatible turntables
Post: # 45760Unread post TheCrates
Tue Jan 24, 2017 2:03 pm
bought two Technics SP-10 yesterday... enough torque for everything.
stefan from hamburg and a few others in here use it, the hamburg cat has a pretty decent setup, check him out.
https://www.youtube.com/watch?v=ZdhGW7BAoKQ
cheers,
sven
ennayess
Post: # 45765Unread post ennayess
Tue Jan 24, 2017 2:27 pm
Hi where can I get ops control panel?
Sent from my iPhone using Tapatalk
TheCrates
Post: # 45766Unread post TheCrates
Tue Jan 24, 2017 2:30 pm
you have to develop your own. u cant buy it. cheers, crates
ennayess
Post: # 45768Unread post ennayess
Tue Jan 24, 2017 2:39 pm
Is the developer on this forum?
TheCrates
Post: # 45769Unread post TheCrates
Tue Jan 24, 2017 2:49 pm
i dont know -but i wrote with him around a year ago via messenger.. he is a very sympathetic and friendly person. cheers, crates
TheCrates
Post: # 45774Unread post TheCrates
Tue Jan 24, 2017 4:18 pm
Another Topic about stefan / moritz and their automation:
http://www.lathetrolls.com/viewtopic.php?f=1&t=3758
Post: # 45831Unread post tragwag
Fri Jan 27, 2017 10:47 am
I would suggest the SP-10 over anything else, confirmed high running torque.
and it works fine with little modification on my system.
fredbissnette
Post: # 45849Unread post fredbissnette
Sun Jan 29, 2017 3:58 am
i have a 1200 on the way going to add torque to it and see if that works
i would love to have an sp10 mk2 or mk3
im assuming an oem deck like reloop stanton denon pioneer would be ok too
erik5553
Post: # 45990Unread post erik5553
Tue Feb 07, 2017 5:51 am
Stanton's support T 120 T560 with cutting head
Stanton T-120/150 has the same parameters with respect to 16 pole motors
CI is worth buying thank you
Gus
Post: # 45992Unread post Gus
Tue Feb 07, 2017 8:44 am
erik5553 wrote:Stanton's support T 120 T560 with cutting head
For Stanton's modification to correct the 0.10 to 0.15 run out needed it's not plug and play
Gus
Post: # 45999Unread post Gus
Tue Feb 07, 2017 2:21 pm
i don't have any experience with that...
handcut
Post: # 46002Unread post handcut
Tue Feb 07, 2017 6:15 pm
Nor do I, its new. As far as I'm aware, its the first serious, new DD turntable for quite some time. Its also quite expensive, but then so are SP-10 mkii's - at least if UK eBay is anything to go by. It will be interesting to see how the new Technics performs, but at £1,300... That's quite a gamble.
I'm wondering how difficult it would be to rig up a DIY solution. Plenty of high-torque BLDC motors around these days... and the technology to control them. Hmmm...
Gus
Post: # 46004Unread post Gus
Tue Feb 07, 2017 6:38 pm
it's not difficult, it's very expensive...
handcut
Post: # 46006Unread post handcut
Tue Feb 07, 2017 6:56 pm
More expensive than £1,300 (€1,500)???
Gus
Post: # 46007Unread post Gus
Tue Feb 07, 2017 7:08 pm
for direct drive yes
for belt drive you can built something like souri did to run the Technics MKII for his vinyl recorder
Voxster1965
Post: # 46015Unread post Voxster1965
Tue Feb 07, 2017 10:18 pm
Have a look at the Numark TTX - user-variable torque control and plenty of it.
Dubcutz
Post: # 46023Unread post Dubcutz
Wed Feb 08, 2017 1:15 am
I'm using a technics SP10mk2, with the additional
Precision plate from VR works well.
