K8 rebuild. Motor trouble.
TThomson
Post: # 45933Unread post TThomson
Fri Feb 03, 2017 7:24 pm
Hey y'all!
So me and a friend started a rebuild of a K8 and now we're stuck on the motor. What we are doing is taking everything and making it its own separate unit.We removed the amp, motor and cutter and put them into their own external cases so we could get rid of the rim drive turntable to eliminate any motor noise and so we can easily hookup/fix any amp problem without having to go into the machine.
What we have here is the same motor, with a 1/4" pulley attached to the turntable. Now we just need to get the turntable to spin at 78rpm. We thought we had all the math right but somewhere we were off and The turntable spins too fast.
I attached so pics so you can see what we've done.
If ya have any ideas pleas let me know! Until then, back to the drawing board.
Gus
Re: K8 rebuild. Motor trouble.
Post: # 45934Unread post Gus
Fri Feb 03, 2017 8:18 pm
if the motor is synchronus you can drive it electronically via motor inverter at any speed you want
http://www.ebay.com/itm/SIEMENS-MICROMASTER-420-AC-DRIVE-0-75kW-1HP-6SE6420-2UD17-5AA1-/252720590590?hash=item3ad7522efe:g:1Z0AAOSw241Ydr1D
more infos here
http://www.lencoheaven.net/forum/index.php?topic=11817.0
and here
http://lathetrolls.com/viewtopic.php?f=1&t=2505
http://www.floka.com/lofi/portable_lathe.html
http://lathetrolls.com/viewtopic.php?f=1&t=2308&p=12244&hilit=premotec#p12244
poor man's inverter is a car inverter 12volt to 110V or 220V through dc transformer 110v or 220v to 12v with Mark's Rob modification
Post: # 45935Unread post markrob
Fri Feb 03, 2017 8:34 pm
How far off are you?
TThomson
Post: # 45936Unread post TThomson
Fri Feb 03, 2017 8:39 pm
markrob wrote:Hi,
Pretty far. The platter is really spinning. We had the motor set up to a dimmer to try and slow it down some but that idea didn't work out that we'll.
TThomson
Post: # 45937Unread post TThomson
Fri Feb 03, 2017 8:40 pm
Gus wrote:Hi,
more infos here
and here
https://lathetrolls.com/viewtopic.php?f=1&t=2505
https://lathetrolls.com/viewtopic.php?f=1&t=2308&p=12244&hilit=premotec#p12244
Our motor is the stock motor from a K8
Jccc
Post: # 45938Unread post Jccc
Fri Feb 03, 2017 9:06 pm
Have you tried the original spindle adapter that goes on the k8 motor that makes it spin on 78?
From the looks of it that spindle adaptor you have on the motor might be too big?
Post: # 45945Unread post markrob
Sat Feb 04, 2017 1:27 pm
Jccc wrote:Have you tried the original spindle adapter that goes on the k8 motor that makes it spin on 78?
That's an excellent point! That pulley looks way too big in diameter. Can you run by your calculations that gave you that dimension?
BTW, you can't adjust the speed of an AC induction or synchronous motor by varying the voltage. You need to use an VFD (variable frequency drive) or inverter. They vary the motor speed by changing both frequency and voltage applied to the motor.
Gus
Post: # 45946Unread post Gus
Sat Feb 04, 2017 3:42 pm
If i'm not mistaken the pulley works right at inner side of platter that means if you attach it at the outside it will run a little faster.
Cheap solution is to machine a new pulley
Gus
TThomson
Post: # 45955Unread post TThomson
Sun Feb 05, 2017 10:47 pm
Well I put the K8 spindle on it and it works perfectly. I was really surprised.
Prestofan
Post: # 45980Unread post Prestofan
Mon Feb 06, 2017 7:28 pm
The pulley on the motor for the K8 is meant to run against a rubber rim on the outside of the turntable. Do you still have it, or did it not come with the K8. The rubber rim is about 1/2 inch thick, so your belt is a little more to the center than the outside of the rubber rim would be, so your speed is not as it should be, but a little off Possibly it won't make enough difference to bother you. You will know when you put a recording on another turntable.
Alan
