Grampian hot stylus adaptor
Cutterwoller
Post: # 46170Unread post Cutterwoller
Tue Feb 21, 2017 7:59 pm
Anyone got a picture of the hot stylus adaptor for the type D head? I need to make one but am not too sure of the arrangement.
Any insights?
Cheers, Lewis
ROLANDJAYS
Re: Grampian hot stylus adaptor
Post: # 46174Unread post ROLANDJAYS
Tue Feb 21, 2017 10:12 pm
i sell one , similar to this
Cutterwoller
Post: # 46175Unread post Cutterwoller
Wed Feb 22, 2017 4:07 am
Aha, that looks pretty neat. Whats the thread gauge for the two tapped holes on the head?
Lewis
Soulbear
Post: # 46176Unread post Soulbear
Wed Feb 22, 2017 4:34 am
Hey Lewis,
Most British Made Electrical "Stuff" of this Vintage, almost exclusively used British Association (B.A.) Screws, Nuts and Bolts :-
https://en.wikipedia.org/wiki/British_Association_screw_threads
They are getting increasingly difficult to obtain, however the Steam and other "Model-Making Fraternity" still use these fasteners, as do Analogue Instrumentation Makers/Manufacturers, so you can "Track them Down"
Regards
:wink: :P :D Soulbear
Cutterwoller
Post: # 46183Unread post Cutterwoller
Wed Feb 22, 2017 7:18 pm
I have managed to now make an adaptor with some stuff I had nocking around. I knew that the screws must be BA and luckily I had some of the exact screws I needed lying around.
I cut and drilled some perspex and mounted springs through and secured the springs with some epoxy. Ill solder the wires to the back side of the springs and put the heater wires in the front.
Posting a picture, hope it goes up...
Voxster1965
Post: # 46184Unread post Voxster1965
Wed Feb 22, 2017 10:19 pm
This is my Grampian BBC with heater mounting - hope this helps.
