external motor for VR T560
luke13
Post: # 54873Unread post luke13
Fri Jan 31, 2020 2:30 am
I would like to add an external motor for my VR machine but as I understand is no longer available from Souri...Does anyone have any solution, perhaps commercial that does the same thing?Thanks in advance
cosmO_O
Re: external motor for VR T560
Post: # 54879Unread post cosmO_O
Fri Jan 31, 2020 2:03 pm
Hey!
If you check the pictures about the external platter motor/driver unit, there is a silver box, it is a papst motor controller, and the motor unit also the same manufacturer, but they carefully cleaned al the brands/logos and part numbers from it.
fredbissnette
Post: # 54881Unread post fredbissnette
Sat Feb 01, 2020 12:39 pm
start calling radio stations and look for a technics sp10mk2
ive found them for a song
it happens
luke13
Post: # 54884Unread post luke13
Sun Feb 02, 2020 4:34 am
Many thanks CosmO_O for your suggestion! Have you an idea of the serial number/model of these papst spare parts? Thanks in advance. For your opinion I also must to add the extra precision plate or can use also with the simple technics?
Thanks in advance to all that help me!
cosmO_O
Post: # 54895Unread post cosmO_O
Tue Feb 04, 2020 9:54 am
rubenr wrote:
Tue Feb 04, 2020 8:23 am
https://idt.ebmpapst.com/content/dam/ebm-papst/idt/germany/products/Brushless_external_rotor_motor_VD_VDC_EN_2017_05_b.pdf
Here is! the motor
and the conector... i try this month
Nice catch rubenr!
Sorry Luke, i never tried to identify the specific motor/driver configuration, if you check the pdf there are part numbers/ physical parameters...
luke13
Post: # 54896Unread post luke13
Tue Feb 04, 2020 1:06 pm
thanks a lot! now I must only find a precision plate to use it (I think I must use it to use external motors)...
cosmO_O
Post: # 54898Unread post cosmO_O
Tue Feb 04, 2020 1:55 pm
Ask MyShank about the precision plate ;)
rubenr
Post: # 54900Unread post rubenr
Tue Feb 04, 2020 5:45 pm
maked! i will have one for more test make ;)
Steven merci send me one ;)
rubenr
Post: # 54901Unread post rubenr
Tue Feb 04, 2020 5:48 pm
CosMoO have you one motor? what dimension have the alu ? depend of the dimesion we have 40 kg torque or 150 :)
But depend too from the wats and rpm.
Please, can u send me how is the messure ?
thx a lot !
Ruben
cosmO_O
Post: # 54914Unread post cosmO_O
Thu Feb 06, 2020 6:06 am
thx a lot !
Ruben
I never own vinylrecorder, just searched the info based on this forum and various pictures.
