Left right phase issue
fredbissnette
Post: # 55264Unread post fredbissnette
Fri Mar 13, 2020 1:31 pm
So I'm making progress with getting my embossed records to play on almost any deck now however I have a problem, when I play them on a crosley sapphire needle they play fine when it's a diamond magnetic cartridge on a regular deck I get the audio seeming to sweep left to right back and forth. Not sure why this is happening, but I'm thinking it's the mounting system I have to my gantry, it's not fancy but there is side to side movement. Perhaps this is the cause, any help is appreciated
Fred
Re: Left right phase issue
Post: # 55265Unread post markrob
Fri Mar 13, 2020 1:51 pm
Can you post a sample? One thought prior to hearing anything: Is it possible that the cheap Crosley has a conical stylus and the more expensive unit is elliptical? In the first case, the tip geometry is able to track both walls of the embossed groove while the other ends up slopping around on the bottom of the groove and reads only one wall at a time? Remember that embossed grooves are more U shaped rather then the V shape you find in a cut groove.
Post: # 55327Unread post tragwag
Wed Mar 25, 2020 2:09 pm
might be off center holes, or the result of varying depth during embossing
