Help identifying some old equipment
- Cmuller0420
Hey there,
I was recently able to acquire some lathe equipment from an old fellow I have bought equipment over the years from. I’m pretty new to the vinyl lathe side of audio, so I kinda know what I have but uncertain what else I would need or what some of these pieces do exactly. (Will attach some pictures)
1. Rek-o-kut challenger. The unit is in pretty good cosmetic shape, now it still needs the electronic test. There is a spare arm for it that is larger that the one currently mounted as well.
2. Rek-o-kut challenger - this one looks rough and is in a home made case it looks like. It doesn’t have the front panel controls that the other does.
3. Rek-o-kut ?? It’s just the motor assembly without the plinth. Looks similar to what is on the two tables above, but a different model number (D15)
4. An even older lathe in a suitcase enclosure. Not really sure what this unit is.
5. Presto 92-B - this looks to be an amplifier used for vinyl cutting?
6. Presto 901A3 - couldn’t find much for info in this at all
7. RCA Attenuation panel type 89-a - don’t think this is for a lathe, maybe old broadcast equipment?
Is the Challenger an all in one system? Or do these presto pieces tie in somehow? The goal is to learn and then eventually move into a stereo lathe.
- Jesus H Chrysler
Re: Help identifying some new equipment
The complete challenger is indeed an all in one unit. The one in the box will need an external amp. The 92-b will be good. Unfortunately I don't see any heads on the second one or the spare overhead. The suitcase lathe is a meissner, needs a ton of work and not worth much, the other presto unit appears to be for a tape machine.
- Cmuller0420
Thanks for the info!
The challenger in the box, would the presto amp work?
Is there any additional processing equipment that would be needed?
https://www.lathetrolls.com/viewtopic.php?f=22&t=8328Cmuller0420 wrote: ↑Thu May 20, 2021 3:00 pmThanks for the info!
