VR Clear box heating modification
David34
Post: # 61916Unread post David34
Thu Dec 08, 2022 8:43 pm
Hi folk..
I have just upgraded my VR with a 275w heater above the platter. Wow what an improvement and even heating compared to the standard side lighting (hard to get globes for them too now!)
Question - I am looking at encasing the VR in a clear box (measurements are: 800mm wide x 400mm High x 700mm deep)
Has anyone sourced anything made already? eg: storage boxes? I would like a flip top lid to access the front of machine, obviously.
If nothing similar is already exisiting (yes! I have googled!!) then I may produce this from some clear plastic sheeting.
The reason for this is to keep the heat within box, and to keep dust out. win win..
If I make these, I may look at posting some pics, and would be happy to sell, or help with this much needed improvement.
Cheers!!
trailerparkjesus
Re: VR Clear box heating modification
Post: # 61917Unread post trailerparkjesus
Fri Dec 09, 2022 8:41 am
This works well but you are increasing static! There are anti static fans with heaters built in on ebay, that is what we use if needed.
SueDenim
Post: # 61919Unread post SueDenim
Sat Dec 10, 2022 6:17 am
Hi David,
Afraid I can't help you with your box idea but was wondering, could post the make & model of that 275w heater you're using please (and/or where you bought it from)?
Soulbear
Post: # 61920Unread post Soulbear
Sat Dec 10, 2022 9:45 am
Hi there,
Hi Trolls,
Due to being Inordinately busy following my house move, I've not had time to make much more progress with this Lazarus Lathe Project. I did however find time to send an email or two to Paul @ http://www.inperspextive.com
Paul has made for me a Totally Superb Acrylic Cover which fits the DR33C like a Charm. I thoroughly recommend his workmanship to any Lathe Trolls needing any similar Covers for their own Projects
Something like this ((Only Bigger!!)) :?: :?: :wink: :wink:
((https://www.lathetrolls.com/viewtopic.php?f=15&t=6818&p=46875&hilit=lazarus#p46875))
If so, give http://www.inperspextive.com a shout out :wink:
Best Regards
Soulbear :P :) :D
David34
Post: # 61923Unread post David34
Sat Dec 10, 2022 3:14 pm
Thanks so much! will look this up!
David34
Post: # 61924Unread post David34
Sat Dec 10, 2022 3:15 pm
Hi David,
I am in Australia. Bunnings have them for $10 on special. I can grab you one (or anyone who pM) , just let me know.. they heat the disc perfectly and evenly.. and quickly!!
Post: # 61928Unread post Aussie0zborn
Sun Dec 11, 2022 5:41 am
David, do you have a link to the heater at Bunnings? Thanks.
David34
Post: # 61944Unread post David34
Thu Dec 15, 2022 12:57 am
They are clearance items but will post a photo soon..
I might buy a few next time I’m in bunnos…
David34
Post: # 61966Unread post David34
Mon Dec 19, 2022 3:57 pm
Here is the brand..
Post: # 61967Unread post Aussie0zborn
Mon Dec 19, 2022 10:01 pm
Thanks David!
Ben
Post: # 62113Unread post Ben
Wed Jan 11, 2023 12:27 pm
Hey David,
Hope you're doing great. Would you mind posting a picture of your installation?
I'd love to see how you set it up
Thanks
Ben
