I am correcting the mis-terminology of myself and others as I go along, sure. I know that everyone claims to be mastering, but I have discovered through Research that the only place that mastering happens is underwater (in the aqueous solution of a Brugnatelli cell - i.e., during Electrodeposition). Every part which is previous to the forming of the master is forcibly a premaster, be it a grandmother (e.g., glass disc with photoresist underbelly) or a grandfather file (e.g., DDP 2.0).gold wrote:You are making it up as you go along. Creating the glass master is called mastering in the optical disc business. Ask the landlord guru. Over at the Gearslutz you used that as an example of proper usage of the termSerif wrote: In CD replication, the glass master is not really a master, either, because it is used to make the metal master for injection-moulding replicates.
gold wrote: If you try making an electroform without a lacquer you don't have a record. That's a pretty serious problem. You'd need something to make that from. Perhaps "master" would be an appropriate term.
'twould be sudden to call the thing that a master is formed atop, also, a master. Master-Master is negative-negative; this would create a forming fail... The sequence of siring can guide the engineer in recalling the word to use for the part s/he is creating. It is clear that the cut lacquer is not male (since she has grooves instead of ridges) and that she is made before the father (aka, master). Therefore, as I have figured out, both the oversized lacquer and big glass mistress are premaster media which are best considered grandmother parts.
...that I know the identity of Laarsø? How so?gold wrote:No one spilled the beans. It's painfully obvious.Who spilled the beans that I know the identity of the avatar, Laarsø? No more sound sheets for Blackwood-san, if it were he... hehe
I'm sure that there is some reason like he didn't want to confuse those who are already confused, so he dropped a shingle that folks will properly misidentify. *L*gold wrote:You should call him and set him straight. He'll like that.What Desmond and company are actually doing is not Finishing
I haven't called MC, however, as I am focusing this tirade on people in a position to know.
However, if he's also somehow able to do plating in his forming shop, without contaminating the cells, he might also be doing finishing work. But electroforming is so exacting a field of Electrodeposition that it is impractical to perform both Arts in the same hopefully-clean room. I don't feel a need to call MCF to set them straight. MCF aren't posting to this thread.
As I have tried to indicate numerous times, this thread is not intended to make anyone change what s/he says or calls his or her own service. It's to correct the name of this section of TSSoLT forum, so that it is not persisting in mis-signaling the craft in question at our secret handshake forum with the word for a craft that no one should be doing when making a record! *L*
By the way, whoever electroformed that dual-speed master which was grandmothered at WMM is doing something right - regardless of what it's called.
Sometimes I wonder why people are so stubborn about words when the only argument I hear against getting this sorted out is that words don't matter. ? Well, if the words don't really matter, then why not correct them?
- Andrew
