is somebody using a dc motor as direct drive on a VMS ?
Nickou
Post: # 13011Unread post Nickou
Mon Feb 28, 2011 10:48 am
Hello ,
I am looking since a long time for a option to replace the lyrec motor by a modern DC motor.
Is somebody already did it ?
or is somebody has a sugestion ... ( I already read the previous topics about that)
about the torq , I beleive than 1 Nm is enough , is it right ?
thanks
Post: # 13018Unread post opcode66
Mon Feb 28, 2011 1:14 pm
It's been suggested that the high pole brushless dc motor from a washing machine could be used.
People use TT's with anywhere up to 12kg-cm or torque.
Nickou
Post: # 13037Unread post Nickou
Tue Mar 01, 2011 7:11 am
yes , I Know
you also wrote you were working on that ...
theartofmastering
dc motor
Post: # 13038Unread post theartofmastering
Tue Mar 01, 2011 9:46 am
Hello Nickou,
What is the use of a modern dc motor as long as the Lyrec hasn't gone down ? You still have to use the same coupling shaft and the same oil dashpot so there won't be an improvement on the rumble figure and tightness of the low end like you get with the Technics motor drive.
Regards,
Maarten de Boer
Emil Berliner Studios
real life is analogue
Post: # 13042Unread post opcode66
Tue Mar 01, 2011 6:09 pm
Not currently working on that project. It is on the list. Working more on P/D comp....
JayDC
Post: # 13044Unread post JayDC
Tue Mar 01, 2011 8:25 pm
is it possible to affix the technics motor drive to a new shaft?
Bonati
Post: # 13047Unread post Bonati
Wed Mar 02, 2011 1:11 am
What's wrong with the Lyrec motor? If it's in good condition and hooked up correctly there shouldn't be any problems. And the Technics motor is unobtainable anyway - no need to spend time fantasizing about that one.
