Cutting polycarbonate or vinyl
mischmerz
Post: # 35854Unread post mischmerz
Fri Jul 03, 2015 7:45 pm
After I applied a bit to much force to my cutterhead, it started to "cut" the poly instead of just embossing. The grooves felt rough and the sound quality was .. well, think sitting under a tin roof in a rainstorm. But it made me wonder: Can one actually "cut" poly or vinyl and get acceptable results (I am talking 78rpm mono). What kind of stylus would be required?
Michaela
Re: Cutting polycarbonate or vinyl
Post: # 35876Unread post tragwag
Mon Jul 06, 2015 2:11 pm
you can cut poly with a diamond stylus.
it's definitely been discussed around here before, have a go at the search function!
dimi751
Post: # 35910Unread post dimi751
Tue Jul 07, 2015 6:34 pm
What are you use to cut poly steel stylus or diamond ?
If your using steel the blank must be at heated at more higher temperature 60 degrees
Using a diamond will get better results and you don't have to heated as much say 35 degrees and cutt will be less noisy
Suggested what tragwag Said search and find, plenty of posts here that's where I learning
mischmerz
Post: # 35948Unread post mischmerz
Wed Jul 08, 2015 7:43 pm
I guess we're talking celsius here ;) I haven't had the guts to buy and try a diamond, so I guess I let the heat lamp do its work. I am going to try that. Thanks.
Michaela
dimi751
Post: # 37207Unread post dimi751
Wed Sep 09, 2015 6:51 pm
Yeah I know how you feel I finally too the plunge and bought a diamond from Steve my shank and some blanks he's really good prices and helpful too
