Anyone used Staticide?
trailerparkjesus
Post: # 54360Unread post trailerparkjesus
Fri Oct 18, 2019 11:15 am
Hey has anyone used Staticide before on the surface of PVC discs for cutting? Could be a good solution for the winter static season coming up!
https://www.amazon.com/ACL-Staticide-AntiStatic-Liquid-32/dp/B002WWNLVO?SubscriptionId=AKIAJD6FR5XRCBOC26MA&tag=ardorseo-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B002WWNLVO
2bitcomputer
Re: Anyone used Staticide?
Post: # 54392Unread post 2bitcomputer
Tue Oct 22, 2019 9:36 pm
Yep.
Been using it for years.
It definitely works.
I'd be interested in your/others' opinion of it...
handcut
Post: # 54410Unread post handcut
Fri Oct 25, 2019 8:33 am
+1
Works great, even when heavily diluted with deionised water.
trailerparkjesus
Post: # 54412Unread post trailerparkjesus
Fri Oct 25, 2019 11:56 am
handcut wrote:+1
Thanks for the input! Going to try!
discosdecorte
Post: # 64644Unread post discosdecorte
Fri Apr 19, 2024 6:31 am
Dear trolls,
Does anyone know where to get ACL Staticide in Europe?
Best regards,
Fer
πŸ„³πŸ„ΈπŸ…‚πŸ„²πŸ„ΎπŸ…‚ πŸ„³πŸ„΄ πŸ„²πŸ„ΎπŸ…πŸ…ƒπŸ„΄
farmersplow
Post: # 64646Unread post farmersplow
Fri Apr 19, 2024 12:18 pm
I have been using this for years.
https://cramolin-shop.de/antistatik-spraydose-200ml.html
Without this spray, the cutting thread usually remains in the groove and is difficult to remove. The "crackling" noise is also almost eliminated.
Do not smoke as flammable, do not inhale, causes eye irritation, use only in well ventilated areas. So not for wimps!
discosdecorte
Post: # 64660Unread post discosdecorte
Sat Apr 20, 2024 5:51 am
farmersplow wrote: ↑
Thanks, mate!
Do you apply it while the disk is spinning and let it dry? Or does it need rubbing for drying?
Best regards,
Fer
farmersplow
Post: # 64661Unread post farmersplow
Sat Apr 20, 2024 1:59 pm
discosdecorte wrote: ↑
Fer
Hi Fer!
A video says more than 1000 words:
So, I made a quick video for you:
1. dripping with wax
2. massage in the wax with a microfiber cloth
3. spray on antistatic
4. massage in with another microfiber cloth (or reverse side)
VIDEO:
Antistatic FP9.mp4
Greetings from Austria
Thomas
discosdecorte
Post: # 64668Unread post discosdecorte
Sun Apr 21, 2024 5:09 am
Thank you very much, very kind of you!
BR,
Fer
Fuzzbox
Post: # 64792Unread post Fuzzbox
Fri May 03, 2024 3:39 pm
Do you have to clean the records afterwards? I use antistatic for clothes from the store target. Works like a charm but leaves a residue. Need to wash of in sink with degreaser and microfiber rag.
discosdecorte
Post: # 64817Unread post discosdecorte
Tue May 07, 2024 6:10 am
Hi!
I've finally tried with this spray and works great:
CRC 83009AF ANTISTATIK 100 200 ML
No need for rubbing or washing, it dries almost instantlyπŸ‘ŒπŸΌ
Best regards,
Fer
