Ciuens, I'm looking at this phase plot and I'm a bit puzzled.Ciuens wrote:After this check, I did another test to measure the phase shift. I used a great program called Smart 7. The result can be seen in the image.
The phase plot seams to be inverted. But it also seams to be offset starting in the low frequencies by -90 degrees. Ideally, the phase should start at +90 degrees at low frequencies.
First, look into the polarity of the signal path from the feedback coil to preamp to your PC. As the low frequency response curve rises, the phase plot should go down. At the first resonant frequency the phase should be zero and start to go negative from there.
Next, reading some info on your program (Rational Acoustics Smaart 7), which is crazy expensive ... there is a phase function that lets you move the 0 reference where you want. I'm not saying it is correct to use it, but if the phase polarity turns out to be inverted, and after you fix it and it still starts at zero try moving 0 up to +90 and see if the chart starts to look correct. There is also a "Coherence" function that you could turn on to see if the measurement data is stable and if it can be trusted. It's a good thing to do until you get a good feel for what you are looking at. After that, turn it off. A high reading (near 100%) says the readings can be trusted, low % readings may indicate a problem like not applying the system delay measurements correctly.
Oh, that brings up another thing - be sure to read up on how to do a system delay measurement and apply it. In your manual - look for "Delay Locator / Delay Tracking". It could be run on the output to input on the PC to see what delays are being generated there and it could be applied to compensate. It could also go through the whole signal chain.
Some things to think about.
If you have time to put a signal flow chart together that would help us as well.
Bryan
