Wow! Nice work!sakuszi wrote:I did this handle a drill and a sander, reamer diamond, diamond-dustedBahndahn wrote:Hey sakuszi, cool part!! Where did you find this? Do you have a link?sakuszi wrote:It is made of titanium for German knives,
I thought over this week as you do with this material [titanium, titanium can be soldered tin]. I've been doing this handle on the knife 10 minutes.
Who can help me with my VR T560 cutterhead?
Re: Who can help me with my VR T560 cutterhead?
- Snug Music
testcut with diamond p340 and Heater but in background, you can hear a little bit the hum from the Steppermotor...
i must be damped...sorry
quite satisfied with the result, I am not. I think as you can get even more! hehee ..
will still try some other tweeter ... smile
- EpicenterBryan
Scotty, that's impressive!Snug Music wrote:quite satisfied with the result...
Did you apply EQ yet?
- Snug Music
hey Bryan,..EpicenterBryan wrote:Scotty, that's impressive!Snug Music wrote:quite satisfied with the result...
Yes i apply an EQ!
have the 120 Hz slightly raised by dropdown 500Hz a bit and had to play a bit in the frequencies 2-16 Khz.
The channel separation is really great! (I believe that is related to the geometry!) The tweeters go but I think there are even better ... will try some time.
am only just a bit sick .. (Virusinfect!)
Let's see which days make me ran times, at the moment I must always sneeze and flies me constantly the spectacle from the head ... smile
But I think that you surely --- lol ... hehee
regards Scotty
Sounds great!!
So you used a 340p stylus? How did you make the stylus holder?
- Snug Music
hhey,..aaron wrote:Sounds great!!
took my old stylus p340 and dremeld a Holder from 3mm Brass.
The P340 sitting conical.
Have tried so long to the old holder sit perfectly in it.
This followed on the pushrods and Soldered and
then I used the new Stylus.
always piece by piece ...
- Snug Music
do not the error and triggered by the holder, if the diamond is in there !!!
I know because as an expert who has already done it! hihii ...
- inspector77
Good work Scooty!!! did you apply inverse RIAA equalization? the quality is amazing, congratulations!
- Snug Music
Yes! I apply an inv.RIAA from caruso-board.inspector77 wrote:Good work Scooty!!! did you apply inverse RIAA equalization? the quality is amazing, congratulations!
I have bypassed the feedback on board and have make a little change by caps and resistors...but i dont' no, i must make more tests...
It's a little bit to bassi...low-pass?? ...I must look by next days when i feel me better.
Regards Scotty
Snug Music !great sound! I'm in shock ! This is a beautiful recording, as cd DIGITAL!
I have not heard that well-recorded vinyl records! Great job, great effects!
My recordings are very, very bad, I have a lot more work on it ...
I burned fuses at the end of recording 1.5 A https://www.youtube.com/watch?v=o47PVGmfuBY&feature=youtu.be
- Snug Music
Hey Saku,...sakuszi wrote: Snug Music !great sound! I'm in shock ! This is a beautiful recording, as cd DIGITAL!
no, no ... not digital cd ... its old analog hot sound..and better /warmer ..hehee, pleased I am still not quite, still have to do more tests! is too bassy and sometimes even a few distortions that need to be balanced, I do not know what it is, .. have to wait probably until my common cold is gone and I can think clearly again ... hehee .. ps: your images are still very, very good, you are on the good way to a 100% result. I had not until many setbacks, yet made more ... ps: try it once with the head, just as I have built it ... I was really shocked by the tremendous quality of the head with the car tweeter!
certainly is an analog recording. I have nothing I have not improved, phase correlation is excellent, I checked on the analyzer, everything is ok!
Very good sound! How inch plate was master? It recording is PVC or lacquer plate apollo?
- Snug Music
sakuszi wrote:certainly is an analog recording. I have nothing I have not improved, phase correlation is excellent, I checked on the analyzer, everything is ok!
Myshank 10" blank!
Great material with very good sound!
Hey Scott
Sounds good!
Whst DB peak is the cut?
Sounds good!
- Snug Music
Record with max.peak is by +3dbThelurker wrote:Hey Scott
Sounds good!
- Snug Music
Caruso_Boardchange
The schematic diagram of the components has been designed for other cutting head to head with other parameters! It will not work properly with your head! Your head will work, only analog equalizer, the best 31 bands stereo company Behinger EQ ! Someone introduced you very misled!
Hey Scotty when you get a chance, can you take pictures of your head with the new stylus holder?
I'm going to try making a head, I got Lanzar TWS 1" titanium dome tweeters
- Snug Music
yes!aaron wrote:Hey Scotty when you get a chance, can you take pictures of your head with the new stylus holder?
i will make a pic.
but in moment, my friend and i change the studio!
can u little bit wait?
Scotty
- Snug Music
Lanzar TWS-1aaron wrote:Hey Scotty when you get a chance, can you take pictures of your head with the new stylus holder?
yeah,..looks good!
