i need help to build a good lathe recorder
record cutter 76
Post: # 51603Unread post record cutter 76
Mon Oct 22, 2018 12:57 pm
helo i need help to construct a nice lathe i have some problems white motor vibrations
record cutter 76
Re: i need help to build a good lathe recorder
Post: # 51604Unread post record cutter 76
Mon Oct 22, 2018 12:58 pm
i need a good mono cutter head if some one have one for sale
dubcutter89
Post: # 51605Unread post dubcutter89
Mon Oct 22, 2018 1:54 pm
why not use your Lyrec?
:D
Lukas
soeffingodly
Post: # 51606Unread post soeffingodly
Mon Oct 22, 2018 2:17 pm
I suggest hitting up piaptk (Mike) and seeing if he has any heads sitting in the lathe cave. He usually does but it depends on what work they may need to get them rocking again.
Mike - Still interested in one of those 5C's when you get around to it. =)
record cutter 76
Post: # 51610Unread post record cutter 76
Tue Oct 23, 2018 2:59 am
dubcutter89 wrote:why not use your Lyrec?
:D
Lukas
my lyrec need som tlc the motor dosent seem to work it jump when you start and then no moren and the rest is up for a big resturation i whant some thing that are more reliable i have it more lika a museum pice than a record lathe right know so its better to try to build the ultimate thing than use to old stuff i think !
record cutter 76
Post: # 51611Unread post record cutter 76
Tue Oct 23, 2018 3:05 am
[quote="soeffingodly"]I suggest hitting up piaptk (Mike) and seeing if he has any heads sitting in the lathe cave. He usually does but it depends on what work they may need to get them rocking again.
Mike - Still interested in one of those 5C's when you get around to it. =)[/quo
okej thank you for the tip . what 5C´s ??
dubcutter89
Post: # 51612Unread post dubcutter89
Tue Oct 23, 2018 5:37 am
Have you tried to spin it by Hand and then switch on the Motor? (really spin fast - at least 78rpm...)
I imagine the lyrec uses a synchronous Motor that does not start on ist own, you have to do by Hand!
Same as with old neumann and telefunken portable lathes...
Check if it is 110V or 220V !
Give it a try!
And if not I'm more than happy to give it a nice place in my lathe museum :D
Lukas
Xertz
Post: # 51629Unread post Xertz
Thu Oct 25, 2018 7:52 pm
Check out the KNOP lathe project.
record cutter 76
Post: # 51631Unread post record cutter 76
Fri Oct 26, 2018 4:20 am
Xertz wrote:Check out the KNOP lathe project.
i while do that thank you for the tipp :)
record cutter 76
Post: # 51732Unread post record cutter 76
Thu Nov 15, 2018 7:43 am
her is a plan on my diy new record cutter i while use a 16 inch platter and a front weel car berings from a golf mk 3 and a roof fan white direkt drive
