Ayima A07 power amp as a cutting amp
12bitcuts
Post: # 61748Unread post 12bitcuts
Tue Nov 15, 2022 8:24 pm
Saw this compact power amp on Amazon.
Wondering if anything about this amp would make it unsuitable as a cutting amp for small lathe setups.
Has lots of good reviews and can be upgraded (OpAmp + PS).
AIYIMA A07
https://www.amazon.com/gp/product/B08CJZGT6H/
Currently on sale w/ $10 coupon.
With included power supply can do 78W per channel @ 4ohms.
That is way more than my cutterhead needs so it seems up to the task.
Any thoughts?
Re: Ayima A07 power amp as a cutting amp
Post: # 61750Unread post markrob
Wed Nov 16, 2022 10:18 am
Looks like it uses a TPA3255 which can support the power they are claiming as long as you provide the proper external power supply. These class D amps are quite cheap now and it should work fine if the the design and build quality is sound. I'd give it a shot. Let us know how it works out for you if you end up purchasing.
