Who says you can't buy anything for $10...
Post: # 58557Unread post 2043
Mon May 10, 2021 3:55 pm
Hello Everybody,
I just wanted to share pics from some items I was lucky enough to purchase in 20/21 for $10 each. Very lucky actually.
First is a Denon DP-1000 direct drive turntable I just received. Rebuilt before purchasing, runs like a dream. Just need to build a plinth for it now.
Second was a Hara m-180 that had a wobbly turntable. I bought it at auction for $10, pulled the platter, tightened a nut and cleaned up the Idler wheel and off and cutting.
Hope that all is well for you.
--Mike
Angus McCarthy
Re: Who says you can't buy anything for $10...
Post: # 58561Unread post Angus McCarthy
Mon May 10, 2021 5:19 pm
Wow! Guess I need to start hitting up auctions. Good finds!
