My First Cut Release
sirkut
Post: # 21Unread post sirkut
Mon Jun 27, 2005 2:31 pm
Here is mine:
Moribund - Silent Lambs 6" Flexi
Moribund is my harsh power electronics project. I also record under spit+smudge and sometime in the future with my sludge/stoner/doom project Great Unwashed Masses. Anyway, I also run sirkut electronics building effects and synthesizers/noise generators for the noise public. Old website still up but will be changed to the new domain when I get a chance.
Steve E.
Site Admin
Post: # 34Unread post Steve E.
Wed Jun 29, 2005 1:48 pm
Now, what am I looking at here? Is this cut into a Solo plate, or is this a pressed Evatone run? The lock hole tells me you probably cut it yourself, but...how?
sirkut
Post: # 35Unread post sirkut
Wed Jun 29, 2005 4:13 pm
Steve E. wrote:Now, what am I looking at here? Is this cut into a Solo plate, or is this a pressed Evatone run? The lock hole tells me you probably cut it yourself, but...how?
Solo trick, two blue "sheets", one transparency printing the artwork sandwiched in the midde, Super 77 spray adhesive to hold it all together. DIY Pic Disc. Next trick I've been thinking about is using spray lacquer to make the writing part easier on the next batch.
Steve E.
Site Admin
Post: # 36Unread post Steve E.
Wed Jun 29, 2005 7:03 pm
I didn't like the CLEAR solo plates for cutting. The shiny ones seemed to screech more as I cut 'em. I had my best luck with the dull side of the purple "signature" plates.
Post: # 306Unread post Aussie0zborn
Wed Apr 12, 2006 7:34 am
Nice work!! Can someone elaborate on solo plates?? thanks.
Itsagroovething
Blank Vinyl any colour or black
Post: # 351Unread post Itsagroovething
Mon May 08, 2006 10:01 am
Hi Guys,
That record looks great but where on earth do you get the blank vinyl from that's coloured like that and cheap??
amok
Post: # 353Unread post amok
Mon May 08, 2006 7:00 pm
Its a Solo brand plate from the grocery store.
Itsagroovething
Desperately need discs Help
Post: # 355Unread post Itsagroovething
Mon May 08, 2006 10:12 pm
Do you know the name of the grocery store, we don't have those types of shops here??
miles.
Post: # 1364Unread post miles.
Wed Jun 20, 2007 2:33 pm
how did you cut such a perfect circle?
Self-lather
Post: # 1418Unread post Self-lather
Thu Jun 28, 2007 9:27 am
Did you use a Recordette to do that? I'm guessing because of the extra hole in the record. So what type of lathe cut this record?
It looks awesome!
-Thomas
