![Smile :)](./images/smilies/icon_smile.gif)
Great stuff! Thanks, particularly interested in the cutterhead files at the moment. Got a couple of overheads and no stereoNedelcu Constantin wrote: ↑Wed Mar 17, 2021 8:14 pmHi ilovedrums247 , yes the screw is M3 and the cutterhead can lose some weight . Mrd i still work on this project but when it will be ready probably i will upload the stl s on this site , if the moderators are ok with this . I continued to work on my recorder , embossing way and i made some improvements such as a second wheel for lead in , lead out and space between the songs , decreased a lot of the cutterhead weight ( thanks Jesus H Chrysler for the tip) so now the speed is more stable and the highs are a little bit better , a wider chassis so i can use bigger turntables , in the video i use a Numark TTX , added a rack vu meter , a gate compressor , in the recording is not used , a better mixer and few other minor modifications ( the colour
))))))) ) . Still mono recording , hope not for long time . All the parts are printed with PLA on an Anet A8 . The song used in the video is by John Junior & Silviu Andrei - Together (Original Mix). Believe me or not i made some records for my friends and they where more than satisfied , mostly because they listened them on cheaper turntables
. Here is a video : https://www.youtube.com/watch?v=on3Jy3H3Y_g
That's great! Many thanksNedelcu Constantin wrote: ↑Sun Mar 21, 2021 4:21 pmHi , I attached here a compressed file with the stl.s and some photos of the embossing head , based on the one made by Souris . For connecting the cones with the needle support i used 1mm carbon fiber rods , also 1mm carbon fiber rods from the needle suport to the cilinders and for connecting the head to the transport section i used a 8mm aluminium tube . The needle is made from 1.6 mm tungsten rod . Everything is glued with a cyanoacrilate gel solution , Mitre Apel AC 400 .
No worries. Mike will take care of you. Also, keep in mind it would be lighter fluid first and then heat up the blank.
I have a VR so the needle is different. (short versus long shank) I am not sure if the diameter is the same or not.Nedelcu Constantin wrote: ↑Thu Apr 08, 2021 3:41 pmHi soeffingodly , sorry for the late reply . Now i work at another version of the lathe , stil embossing . Can you tell me what is the diameter of the needle in the mounting area ? Now i use a 1.6 mm needle but i can modify the needle holder .
