new guy here a few questions
fredbissnette
Re: new guy here a few questions
Post: # 45940Unread post fredbissnette
Sat Feb 04, 2017 7:36 am
this is by far the loudest cut ive been able to get onto lexan
https://www.mediafire.com/?ksh2qiaa457obfm
this is a test cut and not a cut for a client i do not bootleg audio en mass
fredbissnette
Post: # 45941Unread post fredbissnette
Sat Feb 04, 2017 11:22 am
more acid house goodness
love how this style of electronic sounds on lexan
https://www.youtube.com/watch?v=CUKQ4ioo54o&feature=youtu.be
fredbissnette
Post: # 45957Unread post fredbissnette
Mon Feb 06, 2017 5:30 am
https://vid.me/nOo4
https://www.youtube.com/watch?v=dBx6EfkDydU&feature=youtu.be
https://vid.me/Xnec
one off for my collection im not in the business of bootlegging
fredbissnette
Post: # 45968Unread post fredbissnette
Mon Feb 06, 2017 1:41 pm
after doing a bunch of critical listening tests and a-b ing test cuts with originals i have found that i still have a bit of warble issues with the 1200 even after it has been modded for torque
its almost not detectable ona 45 but on a 10 inch the firsrt cm or so has a bit
i may look for a sp10 mk3
cheers
Gus
Post: # 45970Unread post Gus
Mon Feb 06, 2017 3:32 pm
fredbissnette wrote:after doing a bunch of critical listening tests and a-b ing test cuts with originals i have found that i still have a bit of warble issues with the 1200 even after it has been modded for torque
cheers
mk3 is one of the best ever made broadcasting turntables comes with technics sp-02 record lathe motor but too pricey
http://www.ebay.com/itm/Technics-SP-10-Mk3-Turntable-Complete-Power-Supply-Original-NICE-Condition-Rare-/371836570579?hash=item56932fcbd3:g:Z7wAAOSwM4xXYPXs
sp10 mk2 have 6 kg/cm torque it's a nice deck for cutting and embossing at half price
http://www.ebay.com/itm/Technics-SL-1000-MKII-Professional-Direct-Drive-Turntable-/301972543459?hash=item464ef757e3:g:ll0AAOSwvg9XT5gn
also the sp15 it costs between 400-700$ and have 3kg/cm torque it's good for cutting but i'm not sure for embossing
http://www.ebay.com/itm/Technics-Direct-Drive-Turntable-SP-15-with-toner-arm-base-and-cover-/201804807959?hash=item2efc80ff17:g:FnIAAOSw9GhYZtfl
fredbissnette
Post: # 45971Unread post fredbissnette
Mon Feb 06, 2017 3:36 pm
you can hear the warble at the beginning of this 10 inch cut i did
i dont have this problem with 7 inch records
https://www.youtube.com/watch?v=Ux-zHr0mmw8&feature=youtu.be
fredbissnette
Post: # 45972Unread post fredbissnette
Mon Feb 06, 2017 3:37 pm
an mk2 sp10 would work well i think
Gus
Post: # 45974Unread post Gus
Mon Feb 06, 2017 3:48 pm
my opinion is if you are interesting only for embossing why don't you try a Numark TTX1 or Numark TT500 with 4.5kg/cm torque?
Their specifications gives 0.003 Wow&Flutter vs Technics sl1200 mk2 0.002,5 Wow and Flutter
http://www.ebay.com/itm/Numark-TT500-Professional-DJ-Turntable-with-dust-cover-/182436455096?hash=item2a7a0f62b8:g:A8YAAOSwNnRYjF2H
http://www.ebay.com/itm/numark-ttx-turntable/112287223904?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20131003132420%26meid%3Da63fe0531c7b45639acdf9bbedd208f0%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D182436455096
fredbissnette wrote:an mk2 sp10 would work well i think
sold your Mk2 and give a try to Numark if you are not happy then go with sp10 mkii
fredbissnette
Post: # 45975Unread post fredbissnette
Mon Feb 06, 2017 4:59 pm
i would want try one first
Gus
Post: # 45976Unread post Gus
Mon Feb 06, 2017 5:16 pm
Then go with sp10 for sure
fredbissnette wrote:i would want try one first
fredbissnette
Post: # 45977Unread post fredbissnette
Mon Feb 06, 2017 5:28 pm
i have seen sp 10 go for about 1000 on ebay they are not too crazy expensive
Gus
Post: # 45979Unread post Gus
Mon Feb 06, 2017 5:50 pm
fredbissnette wrote:i have seen sp 10 go for about 1000 on ebay they are not too crazy expensive
Be careful do not buy the MK1 it have same torque as the SL-1200 MK2
https://www.vinylengine.com/library/technics/sp10.shtml
fredbissnette
Post: # 45991Unread post fredbissnette
Tue Feb 07, 2017 6:31 am
yes im aware of all the tork differences the mk1 is 1.3 the mk2 is 6 the mk3 is 16
my 1200 is at about 2.5 rt now
fredbissnette
Post: # 46098Unread post fredbissnette
Sun Feb 12, 2017 7:42 pm
i have put my 1200 up on ebay and im gonna buy a ttx
4.7kg of torque should work
fredbissnette
Post: # 46117Unread post fredbissnette
Tue Feb 14, 2017 7:00 pm
picking up a st150 tomorow
ill keep us posted
fredbissnette
Post: # 46130Unread post fredbissnette
Thu Feb 16, 2017 1:07 pm
the hanpin oems dont work at all they have great starting torque and great acceleration but no real moving torque
i modded my 1200 to have a 68k resistace at r209
that works better than where i had it at 100 but i still have a warble
its on pronounced on music with sustained notes but its there
my audio is getting really good
im dead in the water until i find an sp10 2/3
Gus
Post: # 46132Unread post Gus
Thu Feb 16, 2017 2:49 pm
fredbissnette wrote:the hanpin oems dont work at all they have great starting torque and great acceleration but no real moving torque
did you had warble with stanton?
did you try to disable the pitch lock?
As far i know the stanton does not have the same quartz lock as Technics have.
how heavy your cutterhead is? my Fairchild weights 8.25 oz and i don't have any warble problem with stanton
could you upload a video with embossed music on stanton please?
fredbissnette
Post: # 46135Unread post fredbissnette
Thu Feb 16, 2017 5:33 pm
i think it has to do with my needle im using a hyper sharpened tungsten and my cutter head is about 175 g
i need to be able to emboss 10''
i have tried a lot of dif setups
i know a sp10 is the answer
fredbissnette
Post: # 46152Unread post fredbissnette
Sun Feb 19, 2017 3:06 pm
so now im on the hunt for a broadcast deck
called cbc and lots of radio stations
got some lines on asome gates decks
i have my lathe torn apart ready for retrofitting
lathe 4.o soon
fredbissnette
Post: # 46172Unread post fredbissnette
Tue Feb 21, 2017 8:04 pm
i scored two mccurdy ch 12 turntable bases today
i will pick them up sat
i will post my progress on this
cheers
