Things to look out for on a VR setup
manj3000
Post: # 59024Unread post manj3000
Wed Jul 28, 2021 4:15 pm
Hi all I am planning on buying a VR and was looking for advise on setup. What people are using for turntable, amps etc or even a different system altogether
I'm planning on doing short runs of electronic music for my label and hopefully for others in the long run.
thanks
soeffingodly
Re: Things to look out for on a VR setup
Post: # 59031Unread post soeffingodly
Thu Jul 29, 2021 8:57 am
Get a Technics SP-10 MKII for the turntable. 1200's just don't have the torque.
Are you in the US? If so he won't sell you some stuff and you'll need to buy it in the states. I can fill you in on what I needed to buy if you came from the US like I did.
PMST
Post: # 59036Unread post PMST
Fri Jul 30, 2021 3:04 am
Yeah if you want to cut loud 12" for sound system use (which need to be cut at a reasonable volume) then a SP10 MKII for sure. Also no idea where you are based, but if you are in Europe this is a good place to buy a plinth to sit the SP10
https://www.ebay.co.uk/itm/353083644031?fbclid=IwAR3LL9s9mvZrdhZjIRHoGpn9W1qD2WewRyL-9JvyU6Hw1Jsoj2tIfiYC_XE
manj3000
Post: # 59040Unread post manj3000
Fri Jul 30, 2021 2:24 pm
Thanks for the advise, I'm based in the UK
e3sa934
Post: # 59199Unread post e3sa934
Fri Aug 20, 2021 5:03 pm
Well, I use a 1200-GR with my VR (it has a similar 'footprint' to the mk2) and the torque is perfectly fine, I've had no wow/flutter issues at the outer edge of 12" cuts which was somewhat of an issue with the 1200 mk2 which I'd previously been using
boryo
Post: # 59201Unread post boryo
Sat Aug 21, 2021 5:49 pm
I'm using SP-15 and cutting loud and punchy hip-hop, so this one also works and cheaper than SP 10 MK2
soeffingodly
Post: # 59215Unread post soeffingodly
Mon Aug 23, 2021 9:18 am
I have both but SP-15's are known to go haywire and they have crazy chips that are not available anymore. That is why I upgraded when I got the chance.
