Hi guys,
i am trying to figure out what tool to use to write on the surface of the disc. I am talking about writing serial number, artists names and so on, in the lead-out section of the record.
i did some engraving with a simple needle but i loose control over the text and the result is not good at all !
i found this pens but i am not sure this is right (see attachment)
Please, can you show the tool you are using to keep this practice smooth and easy !
Engraving pen ? what tool are you using?
- urieldeveaud
- martinstamper
Re: Engraving pen ? what tool are you using?
Curious what other people use. I use these, I do however dull the end a bit with some sandpaper before using them though so as they're not too scratchy and personally I can't distinguish from anyone elses scribing on lacquers.
https://www.amazon.co.uk/QWORK-Tungsten-Engraving-Retractable-Ceramics/dp/B09DG6NFLM/ref=sr_1_3_sspa?crid=1K0S1EJ8P92WX&keywords=engraving+pen+tungsten&qid=1644790208&sprefix=engraving+pen+tungsten%2Caps%2C76&sr=8-3-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzOVBWM1o4WUlXNUdDJmVuY3J5cHRlZElkPUEwMjE2MjM4M0JVQzM3TDAxOEpMQiZlbmNyeXB0ZWRBZElkPUEwMzMwNzMzMU05MlNPVTUyMlRBTiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
- RedSpadeRobyn
I have 2 of the ones in the photo. The 1st on the left and the last on the right. I just use them for scribing into petg and poly carb. I don’t cut lacquers, for what my experience is worth.
