VR Dashpot oil
msartori
VR Dashpot oil
Post: # 60652Unread post msartori
Tue Apr 26, 2022 5:17 pm
Hello,
what type of oil can I use in my VR?
I found in the forum this one:
Motul SAE 50 monograde oil
Is it Correct?
Thank you
SueDenim
Re: VR Dashpot oil
Post: # 60661Unread post SueDenim
Wed Apr 27, 2022 1:04 pm
That will definitely work ok.
Personally, I use a 40 weight (W40) fork oil, but it really doesn't matter too much. Just be aware that the oil's viscosity, and therefore how much damping it provides, will change a little with room temperature. So if you're cutting in a very hot climate, go with a slightly higher weight.
msartori
Re: VR Dashpot oil
Post: # 60672Unread post msartori
Thu Apr 28, 2022 4:35 pm
Thank you!
boryo
Re: VR Dashpot oil
Post: # 60676Unread post boryo
Fri Apr 29, 2022 1:59 am
So in best case we need some oil that does not get affected by the temperature?
ilovedrums247
Re: VR Dashpot oil
Post: # 60691Unread post ilovedrums247
Sat Apr 30, 2022 7:06 am
Silicon oil is fairly resistant to temperature fluctuations, and can be found in many weights for RC auto shocks and differentials.
PMST
Re: VR Dashpot oil
Post: # 60705Unread post PMST
Wed May 04, 2022 3:40 am
I use Motul SAE 50, but as SueDenim said, the viscosity changes with temp and the head can get lighter through the day in the summer out here.
