- Steve E.
- Site Admin
Re: Scam warning: Angulo Records
Mecanismo tecnologia FESTO
Cuerpo de acrilico negro de 10mm.
Regulador de temperatura de diamante
Regulador de ancho entre surcos
Regulador de profundidad de corte
Regulador de angulo de ataque
Regulador de alturqa de cabezal
Motor de 50 kilos de fuerza
registro de 22minutos en 12" 33 3/3 rpm
registro de15 minutos en 12 en 45 rpm
Cabezal estereo 500W RMS. Respuesta de frecuencia 10Hz. – 50Khz.
El equipo puede ser equipado según las necesidades del cliente aumentando el costo con equipamiento adicional, potencia de 500, ecualizadores , Vumetros, display, controlador automático etc.
FB translation to English:
A Tape Recorder Vinyl within the reach of all!! Usd$$ 1800 -.
Mechanism technology festo
Body of Acrilico Black 10 mm.
Regulator temperature of diamond
Regulator wide between grooves
Regulator depth of court
Regulator of angle of attack
Regulator Alturqa from cabezal
Engine of 50 kilos of force
Record of 22 minutes in 12 " 33 3/3 RPM
Registration De15 Minutes in 12 in 45 rpm
Cabezal Estereo 500 W RMS. Response of frequency 10 Hz. - 50 Khz.
The team can be equipped according to the needs of the customer by increasing the cost with additional equipment, power of 500 Ecualizadores Vumetros,,, display, automatic controller etc."
http://vinyldiscrecorder.wix.com/vinylrecorders
After angulo records... now let's name it "vinylrecorders". What an original and awesome name.
And of course :
https://www.facebook.com/VinylRecorders
And of course :
http://www.myshank.com
skype : steven.myshank
* Resharpening services
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
- Steve E.
- Site Admin
The Facebook page is no longer visible, at least to me. But WHAT is going on with that Wix page?? There are closeup videos of a steel-needled Victrola being played, in the background. What does THAT have to do with this product?
Is the chuck an actual Victrola? It looks exceptionally well made compared to what this guy can make... I was wondering if he took a machining course in the meantime, but thinking again, he probably just did a PhD in cheating...
Please edit the title of this topic to his new name.
He just wants to be forgotten with the old name.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
- Steve E.
- Site Admin
The problem is that it is SO close in name to the very legit Vinyl Recorder (no S) of Souri in Germany.
In that case, name it : http://vinyldiscrecorder.wix.com/vinylrecordersSteve E. wrote:The problem is that it is SO close in name to the very legit Vinyl Recorder (no S) of Souri in Germany.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
- Steve E.
- Site Admin
Re: Scam Warning: non-Souri "VinylRecorderS"
I created a separate thread with a related warning, and directed it to this thread for the sake of continuity:
http://www.lathetrolls.com/viewtopic.php?f=29&t=6054
Steve E. wrote:This is where it gets confusing, for those who are just getting into record cutting.
OK. First of all.
NOT a scam. LEGITIMATE PRODUCT:
Souri's Vinyl Recorder or VinylRecorder:
http://vinylrecorder.com/
Souri has been doing his thing since before our site has been up.....so, over ten years. RELIABLY. Many of our site users use his product, T560; some -- several? -- have used it professionally for years. As with any system, there are pros and cons to it, and you can search the site for ongoing discussions about it. It involves an investment in equipment, an investment in training, and proprietary blanks. Those who choose to use it have decided from the available data that it's a good match with their needs.
So, now, suddenly, we have this.
Scam. ILLEGITIMATE PRODUCT:
Angulo's "Vinyl Recorders" (with an "s" at the end) or "Vinyl Disc Recorde" [sic] or "Vinyl Disc Recorder":
and
(Which I can't seem to visit. if YOU can, please post screen shots.)
The main discussion is in this other thread, which any members are encouraged to contribute to:
http://www.lathetrolls.com/viewtopic.php?f=29&t=5854
I wanted to post a separate thread for the sake of the title.
Angulo seems to be a moving target, most likely changing his name to avoid our warnings.
- pandapolar
i dont know if anyone has seen this but looks like Angulo (now Vinyl Recorders) is tackling the cutterhead issues pehaps??
still just a 3d design though ..
https://www.facebook.com/VinylRecorders/videos/957869657591893/
- Steve E.
- Site Admin
Post screenshots, if you can. I seem to be blocked from visiting that page.
- pandapolar
On Facebook:
A preview of the new design...... Bravo HT
Guys ... these images are of a design of a user Tarcisio Giustino. Tarcisio is my friend and has been working in this cutting head a few months. Even sent me pictures of finished parts made of metal. Raul (Angulo) is using someone else's project to promote.
The following images Tarcisio sent me: Tarcisio informed me that is producing some pieces to sell soon.
Hey Angulo, shame
Ciuens
Hey Angulo, shame
Ciuens
- pandapolar
WOW! thats crazy
- Steve E.
- Site Admin
How would Raul have gotten these designs? Can Tarcisio weigh in on this? He is a member of this forum.
- EpicenterBryan
He is much closer but still doesn't get the whole torque tube / V spring thing.
He needs to watch this and pay close attention:
Bryan
Bryan
- Vice Fiori
Aaaand, not happy, Raul try to sell his magnificent piece of crack on "mercadolivre" in BRAZIL:
http://produto.mercadolivre.com.br/MLB-710498422-gravador-de-disco-de-vinil-grave-suas-musicas-em-vinil-_JM#questionText
Well, I'm just going to point out a technical observation about the video. Bryan constructed does in fact represent the motion of the the stylus when given left channel or right channel or left and right channel simultaneously. Bryan's rig shows the lateral and vertical motion of the stylus.EpicenterBryan wrote:He is much closer but still doesn't get the whole torque tube / V spring thing.
However, mechanically speaking, it is not a proper representation of the actual physics involved to make this happen in a 45/45 torque tube style stereo arrangement. I say this confidently and without equivocation. The rig has hinges where the push rods meet the torque tube. Also it has hinges where the push rods meet the servo. Yeah, that alone makes this only a demonstration of the movement of the stylus and not a demonstration of the true mechanics of the torque tube system. FYI. This will all be detailed in my ebook on cutterhead theory and practice. And, I'm thinking Angulo will probably want to read it once published.
In the meantime, you can also watch this video of the motion of the stylus. More to come soon.
And here we go for the last update : https://www.facebook.com/VinylRecorders/videos/999657483413110/
Just have a look on the description"video next process Direct metal mastering DMM"
Seriouly, can't wait to see that.
* Blank records
* Cutting lathe
* Blank records
* Cutting lathe
You can see in the video that the man has done a lot of work, but the effect miserable at the moment, you can hear a large distortion, perhaps by a webcam microphone, but I do not know .... Did he cut, pressed steel sheet? What is this material plate?The Shank wrote:And here we go for the last update : https://www.facebook.com/VinylRecorders/videos/999657483413110/
VinylRecorders on Youtube.
https://www.youtube.com/channel/UC0JVdlWJGFpGLh7Glv55jKg
Is it the same person?
