SCAM: Rare Vanrock E-101 Vinyl Record cutting Lathe machine - AKA Atom A-101
Distinct from the "Members Only" section about business disputes, this is a section for those sellers who have distinguished themselves by scamming multiple customers. AND for sellers who have ghosted customers during long delays. If you intend to start a thread here, you must check with Steve E. first -- this forum should only be a LAST RESORT.
maxned
Post: # 58875Unread post maxned
Mon Jun 28, 2021 6:13 pm
A fully automatic record cutting machine from the 80's in beautiful condition. This lathe cuts 7" inch blank records on 33 or 45 rpm.
Comes Including the original stylus, record clamp, three manuals (photocopied) and the original electrical cable.
With this machine you can control input levels of line or mic (mono) There is a compressor controlling the input level (Great for protecting your stylus). You can fine-tune the platter speed on both speeds. This unit can cut lacquers, PVC, and polycarbonate blanks, even CD's with the correct stylus. Comes in a beautiful suitcase. It's very compact and you can carry it with you anywhere and even start a mobile cutting booth.
This machine is working, platter and motor drive belts replaced to fresh ones. Power turns on, platter turns, lathe moves forward and backwards, input + VU meter works, cutter head receiving signal. Runs on 100W (not the American 110) which is the Japanese power rating, you will need a converter depending on where you are.
Asking $3000
skidder
Re: Rare Vanrock E-101 Vinyl Record cutting Lathe machine - AKA Atom A-101
Post: # 61166Unread post skidder
Wed Jul 20, 2022 6:25 am
Hello, where did you find belts?
Steve E.
Site Admin
Post: # 64159Unread post Steve E.
Fri Feb 09, 2024 2:37 pm
Did anyone get scammed on this?
