Reel to reel machine
Stuff not covered by the other...Forii? whatever. General goofiness. (You should not post here unless you've been contributing elsewhere on this site.)
bancho
Post: # 21184Unread post bancho
Fri Sep 28, 2012 5:45 am
So... I'm in love with anything analog (well, we live in analog life) and I have some questions about reel to reel tape decks:
I own actually new Revox B77, in notime I'll own PR99 also. My dream is also Studer A80 (sorry dr.dub but for a start 2-track not 24 ;) ) and recently found Telefunken... and here is the question:
Does anybody have the Telefunken M15 or M10 (especially this one!)? Is it any good - compared to Revox/Studer? How hard is it to repair it? Are the parts obtainable?
The Telefunken M10 with V86/V87 amps is super sexy - check the web! :D
Nickou
Post: # 21185Unread post Nickou
Fri Sep 28, 2012 7:01 am
I have a M15 and had a M 10, they are fantastic machines , top quality ...
dubcutter89
Post: # 21186Unread post dubcutter89
Fri Sep 28, 2012 7:24 am
one of my favorite - would like to have one somtime....
i guess the telefunkens are on the same level as the studers - professional
the only thing is that those old german decks often have the german headstock,
which is on the outside - so you may have problems playing back "normal" tape (or you have to rewind or whatever)
Lukas
bancho
Post: # 21188Unread post bancho
Fri Sep 28, 2012 8:27 am
What about repairing... the one I could get will have to be dissasembled, cleaned and reapired... The spare parts are very hard to get... Is there any reapir service available for these dinosaurs?
And yes... I've noticed the head is placed opposite as normal head placement (as B77)... this is probably the so-called "german track path", right?
Does this mean you just rewind and turn the tape? Anybody know?
bancho
Post: # 21189Unread post bancho
Fri Sep 28, 2012 8:29 am
Oh!
What is considered as "normal" price for the M10 and M15 thesedays?
bancho
Post: # 21190Unread post bancho
Fri Sep 28, 2012 8:31 am
heh, another question ... bit different....
I'd like to modify my B77 to have balanced connectors (now there are unbalanced "cinch" connectors). Does anybody know how to do that?
Thanx in advance!
dubcutter89
Post: # 21192Unread post dubcutter89
Fri Sep 28, 2012 9:06 am
use a 1:1 transformer = "übertrager"
simple, adds to sound + true balanced
lukas
ps.: m15 are cheaper than m10 (i guess)
price 0-1000$
bancho
Post: # 21193Unread post bancho
Fri Sep 28, 2012 9:23 am
dubcutter89 wrote:use a 1:1 transformer = "übertrager"
emmm... I think I don't quite get it :?
could you draw this?
Nickou
Post: # 21194Unread post Nickou
Fri Sep 28, 2012 10:16 am
bancho wrote:What about repairing... the one I could get will have to be dissasembled, cleaned and reapired... The spare parts are very hard to get... Is there any reapir service available for these dinosaurs?
hilpert in Germany is doing it
flozki
Post: # 21195Unread post flozki
Fri Sep 28, 2012 10:32 am
User ina134 drv134 or equivalent from THATs i think there ist no space to put good sounding transformers in.
Post: # 21197Unread post tragwag
Fri Sep 28, 2012 12:54 pm
I would swear by studer. those machines are dead accurate as far as wow/flutter, and are intuitive to use. (i've used the A827, 24 track machine)
bancho
Post: # 21198Unread post bancho
Fri Sep 28, 2012 1:36 pm
@flo & lukas: do you have any schematics and/or recommended übertragers ? I have the b77 in the original "desktop" case and I want to put it in the some kind of wheeled rack so the space shouldn't be a problem... for the ina/drv 134 ... do I use a preamp and connect it to ons & outs?
@tragwag: I know the studers are standard first thought but I'd like to know about telefunkens a little bit more as they are cheaper - but good enough? it looks so...
dubcutter89
Post: # 21202Unread post dubcutter89
Sat Sep 29, 2012 5:29 am
well, i was thinking about external transformers.
you don't have to disassemble the machine nor make any modifications.
just use a transformer (per channel) with your cinch connection on one side,
and xlr (or whatever balanced system you need) on the other.
1:1 ratio
cheap ones for 10€ (may sound nice as well)
pro ones (telfunken, lawo, haufe, malotki....) for 100€+
google line transformer...
the ina134 drv134 are nice, but you have to make a pcb (or proto-board)
power connection, drill holes etc...
for balanced out on your revox you would need 2 drv134.
more info in the datasheet:
http://www.ti.com/lit/ds/symlink/drv134.pdf
(page 8)
will cost approx 20€ for stereo
Lukas
bancho
Post: # 21203Unread post bancho
Sat Sep 29, 2012 8:17 am
I don't have any problems making pcb... the thing is which is better transformer or ina134 drv134 ... probably I'd have to make one/channel so total 4 of them (L/R for in/out) ? ...and all the elements should be approximately the same value otherwise there will be discrepancies between L/R?
petermontg
Post: # 21221Unread post petermontg
Sun Sep 30, 2012 11:25 am
There is also ortari mtr 12 and 10, serif put me on to them a while back. There is a studer here for sale but needs work, plugged into wrong power mains.
If you want to PM me I'll pass along the sellers details.
Peter
MrMegaEli
Post: # 21222Unread post MrMegaEli
Sun Sep 30, 2012 3:58 pm
I know where you can get restored A810 2 tracks for $2,500, in NYC. PM me for details.
bancho
Post: # 21230Unread post bancho
Mon Oct 01, 2012 8:22 am
Thanks everybody!
Right now I'm looking for something cheap and pro (these two things don't go together, I know) and in EU. I could get restored Telefunken M15 for around 1k€, the M10s went for 1.1k and 1.6k - too much for me right now.
Anyway I'm just looking around if I could find something - I already have new B77 wihch is more than suitable for me at this moment :)
flozki
Post: # 21232Unread post flozki
Mon Oct 01, 2012 12:15 pm
M10 you shoud get for under 500.-
i saw recently one for 200.- which also needed work.
for your B77 i think its better to use the INA/DRV134 or the ones from THAT.
for a transformer solution you must have the right output circuit..capable to drive enough.
i think to use transformers you need also some more transistors, opamp whatever.
the schematics for INA134 is so simple that you can add it almost on the fly.
only the caps for power needed.
i dont know the B77 schematics. so it might be a problem to have symmetric voltage for DRV/INA solution.
Post: # 21246Unread post Aussie0zborn
Tue Oct 02, 2012 2:57 am
You will find a webiste from a German company that specialises in Telefunken tape machines such as M15, although not with preview heads. These are good solid machines and Neumann supplied them as part of the complete VMS70 cutting suite in a cabinet that matched the look of the the VMS70 cabinet.
bancho
Post: # 21339Unread post bancho
Tue Oct 09, 2012 6:03 am
@flo: If it happens you come across of the complete M10 (including V86/87) for price you mentioned... please let me know immediately! :)
