new diamond styli available
The Shank
Post: # 9894Unread post The Shank
Thu Jul 22, 2010 11:35 am
Well, first feedback from cutting on VMS70 and SX74 :
we have a distorsion in the trebles because of a to long stylus OR a tip to small (1um)
Now we get hollydays and next test will be done next month. Problem should be solved in the same time.
It sounds good but not enought. We did only laquers tests.
kgutzke
Post: # 9911Unread post kgutzke
Fri Jul 23, 2010 3:15 am
If diamond needle can be ordered for Westrex head - please count me in on a pre-order. I'd love to do some testing as soon as possible.
The Shank
Post: # 9914Unread post The Shank
Fri Jul 23, 2010 7:44 am
every shanks are available, the only thing are the specs you have to let me know
andybee
Post: # 10038Unread post andybee
Sun Aug 01, 2010 11:20 am
hey all diamond cutting freaks out there,
maybe it was a bit to early to post here at the classifieds :)
I still wait for my test sample.
any updates will posted here.
thanks a lot!
andreas
aaron
Post: # 10245Unread post aaron
Sat Aug 21, 2010 1:25 pm
In another post on here, it was said that if the grain of the diamond isn't taken into consideration, that's when they prematurely break... are these stylii made in such a way that this isn't a problem anymore? I know that's one reason that's prevented me from getting a diamond so far... the uncertainty of whether or not I got a "good" one.
andybee
Post: # 10710Unread post andybee
Sun Sep 26, 2010 9:37 am
Hi all!
Here is a small update:
I received the first sample, I test it the next days...
The diamond looks very good!
A correct mounting and chip suction is needed,
otherwise the diamond can brake fast.
the manual will also be updated....
correct angle (0-5degrees) is also important for lifetime.
there will be absolutly no guarantee for diamonds, because
nobody can control the installation/cutting process.
more news soon :)
piaptk
Post: # 10714Unread post piaptk
Sun Sep 26, 2010 9:26 pm
Is it still looking like a 160 Euro pricetag?
The Shank
Post: # 10768Unread post The Shank
Fri Oct 01, 2010 7:45 am
piaptk wrote:Is it still looking like a 160 Euro pricetag?
no no, Price actually is 250€. We didn't order enough pieces to get a so nice price. Pre order available now. Just PM me.
aaron
Post: # 10771Unread post aaron
Fri Oct 01, 2010 11:14 am
What will the price be after pre-orders?
The Shank
Post: # 10772Unread post The Shank
Fri Oct 01, 2010 11:35 am
aaron wrote:What will the price be after pre-orders?
I can't say anything because we don't know...I guess it's already pretty nice to have strong diamond stylus available...Strong and cheap, MAYBE later....
piaptk
Post: # 10793Unread post piaptk
Sun Oct 03, 2010 6:44 pm
What kind of shanks are available with the preorder?
The Shank
Post: # 10799Unread post The Shank
Mon Oct 04, 2010 11:12 am
piaptk wrote:What kind of shanks are available with the preorder?
SC99/SX74 and Vinylrecorder.
Others on request, but all availables.
piaptk
Post: # 10802Unread post piaptk
Mon Oct 04, 2010 1:40 pm
I will preorder one if I can get it on a presto long shank.
How long are these things holding up? I was really hoping there would be an option that was significantly cheaper than vinylium, rather than just a few euros savings. But I'm willing to shell out the money just to not have to deal with Vinylium's (lack of) customer service and to avoid using an adapter.
aaron
Post: # 11102Unread post aaron
Sat Oct 23, 2010 7:13 pm
When it is said that the angle needs to be between 0 and 5, is that assuming that 0 degrees = cutting face perpendicular to the blank? And 5 degrees, what direction is that? Does that mean 5 degrees off the perpendicular toward the incoming blank (if that makes sense)? I've always wondered that... for example, if you were using a presto head, I would think that 5 degrees would mean you'd lean the head back 5 degrees (from perpendicular) toward the suspension/lathe unit. Is that correct?
Post: # 11104Unread post opcode66
Sun Oct 24, 2010 12:57 pm
People would tilt the head back. If you imagine the line the cutterhead travel along the feedback screw as being a horizontal line, then the cutterhead would be tilted on that axis. I've actually seen people tilt the cutterhead both ways. Some tiltinig the stylus side down. Some keeping the stylus side up. I believe stylus tilted down by 5 degrees from the lateral across the disc is the norm.
