Ebay : Technics SP10 Turntable
- castillian500
Technics SP 10 turntable on Ebay. Am I right about this is this truly a cutting lathe ?
http://www.ebay.com/itm/TECHNICS-BY-PANASONIC-MODEL-SP-10-TURNTABLE-/221183838047?pt=Vintage_Electronics_R2&hash=item337f95875f
Re: Ebay : Technics SP10 Turntable
It's a turntable only. But so good that if you put a Vinyl Recorder or Vinylium overhead cutter on it, you would have a pretty good lathe.
castillian500 wrote:Technics SP 10 turntable on Ebay. Am I right about this is this truly a cutting lathe ?
That one has a linear tracking arm... and it's the older model, not the same motor..
You'd want at least a SP-10 MKII with a SH-10E to use as a cutting turntable.. if you can afford the SP-10MKIII it's the same motor as a SP-02 Motor upgrade for the Neumanns..
generally its for reproduction.. but i like to play wif it sometimes..
Nice removals , thanks !
Technics SP-10 MK2 STARTING 6 kgs *cm , Flutter 0,035 % the moment of inertia 380 kgs . cm2
Technics SP-10 MK3 = SP-2 STARTING 16 kgs * cm , SPEED DRIFT + / - 0,001% Moment of inertia 1100 kgs * cm2
Here is one for you castillian Go for it man
http://www.ebay.com/itm/Technics-SL-1000MK3-or-SP10-MK3-with-EPA-100MK2-arm-and-SH-10B5-base-/300806546062
here is another one:
http://www.ebay.co.uk/itm/350722942281
- castillian500
I am better off with a Technics SL 1210 MK5G at $ 1300.00. I was wondering what kind of arm was on that SP 10. It looked like a cutting arm. A linear arm ? Never heard of that but I am inexperienced. $ 14 grand and $ 7 grand for an SP 10 ? That's insane ! They are 30 years + old and I am sure a nightmare with parts. Not practial.
There is no tonearm. You mount the motor platter into a plinthe that has a tonearm on it. So, you can use an sp10 with whatever tonearm you like.
