Hey, guys,
I bought this motor and PWM controller off eBay; the combination cost me something under $20. It's a really nice little inside-out motor with a planetary gear reducer, giving it enough power to drive a leadscrew through an O-ring belt and pulley arrangement for further speed reduction and vibration isolation.
Although the motor does include a Hall-effect sensor for full closed-loop speed control using an Arduino or other alternate controller, the PWM controller in open-loop mode gives excellent speed regulation with low 'source impedance'; that is, when you try to slow the motor down, it pulls more current to maintain the speed that's been set. Feedback uses back-EMF from the motor, which is sensed by the controller board to vary the motor drive. The little pot on the board allows continuous and smooth speed adjustment between 7 r.p.m. and 57 r.p.m. at the shaft, and the speed stays very constant over time and with normal load variations. The pot can be replaced with an external reference voltage input for variable-pitch cutting. The board needs 12VDC at about half an amp; an appropriate 'wall wart' would work just fine.
The motor spins with very little vibration, and the speed reducer gives it plenty of torque. It ought to be adaptable to a Presto or Rek-O-Kut type of overhead, and should not induce motor noise into groove, even if mounted right on the overhead with appropriate rubber isolators.
I bought this hoping that the speed range would be enough for cutting and for spiraling. But an 8:1 speed ratio isn't sufficient for that. Cutting at 200 lpi, the spiral would be only 25 lpi. Good enough for between bands, but not for the lead-out. So make sure that your leadscrew clutch arrangement will still allow hand spiraling with the motor driving the screw.
As I said, I have less than $20 in this, and will be happy to let it go to an interested Troll for $30 via PayPal, which includes shipping to any US location. Leave a PM if you are interested.
Leadscrew motor - cheap
- grooveguy
Re: Leadscrew motor - cheap
Still have it.? I am interested.
m.
m.
