The Magnetovolt "Curreg": Stylus Heater Supply
The Magnetovolt Curreg is a current regulated DC power supply unit, specifically designed for heating the stylus filament on disk mastering systems.
It can deliver up to 2A at 15VDC, capable of heating all commercially available styli as well as custom-wound heater coils. It can also be wired for a limit of 1A or 1.5A for finer resolution.
It is built with high quality heavy duty components for continuous reliable operation, and comes with several built-in safety features.
The outputs are fused to protect the load against accidental excessive current settings, there are voltage and current meters, as well as an easy facility for emergency shut down.
The current setting knob is part of a control circuit which does not pass the load current, from added longevity and reliability. Outputs are offered on both the front and rear panels.
It is handcrafted, soldered and screen-printed on demand.
Please visit http://www.magnetovolt.com for further details.
