Studer A-80 repair
jjgolden
Studer A-80 repair
Post: # 31151Unread post jjgolden
Mon Aug 25, 2014 4:10 pm
Hi
I have a Studer A-80R that I'm trying to get running.
My first issue:
When I turn on the power, The LOC and tape path lights are illuminated but nothing else is functional.
I took a reading from the +20 & +24v points on the Stabilizer card and they read 1.3mv and 42.2 mv respectively.
I checked the fuses in the fuse bay and they all have continuity.
Any help/direction from this point would be greatly appreciated.
JJG
studiorp
Re: Studer A-80 repair
Post: # 31159Unread post studiorp
Tue Aug 26, 2014 4:10 am
Check all capacitors electr., diodes, resistors, etc.
jjgolden
Post: # 31160Unread post jjgolden
Tue Aug 26, 2014 12:13 pm
Ok thanks,
Will do the control unit cards first and repost any progress.
JJG
ejemmons
Post: # 31161Unread post ejemmons
Tue Aug 26, 2014 12:48 pm
I'd check the pass transistors for the logic PSU, they're on the deck casting. Do you have a manual? I have two A80 multis, and they're pretty solid. Also the Frako electrolytics are probably suspect, simply due to age. I MAY have an extra manual for the A80-16, which would largely apply... have to look.
RA-1574E amps.
jjgolden
Post: # 31162Unread post jjgolden
Tue Aug 26, 2014 1:08 pm
Thanks ejemmons,
I have a PDF manual for the A80RC MkI & MkII which should apply for this issue?
Mine is a A-80R (ML-5 / Mark Levinson) model. I think the only difference with the ML-5 is the audio electronics.
Pass Transistors: are those the 9 that can be seen from the back up under the deck next to the hanging caps?
Thanks for your input,
JJG
ejemmons
Post: # 31164Unread post ejemmons
Tue Aug 26, 2014 3:30 pm
Yes, they are, and either manual should work. How about the other pwr rails?
RA-1574E amps.
jjgolden
Post: # 31166Unread post jjgolden
Tue Aug 26, 2014 6:21 pm
Got it working!
It was a bad 220/25v cap on the Stabilizer card.
Thanks for the help & input! :D
JJG
ejemmons
Post: # 31170Unread post ejemmons
Tue Aug 26, 2014 9:34 pm
Yay! I'd contemplate a recap of all electrolytics and tantalums. Did this on the 24 track, cured a large pile of ills in one go!
RA-1574E amps.
jjgolden
Post: # 31177Unread post jjgolden
Wed Aug 27, 2014 11:46 am
EJ,
Good to know! That'll be next on the list of to do's.
The Mark Levinson audio Cards are a little funky too.
They may not be possible to get into with their solid moulded circuit blocks. (copy protecting the design I guess?)
Thanks again!
JJG
misjah
Post: # 45570Unread post misjah
Fri Jan 13, 2017 3:46 pm
for anybody repairing their A80, I have new logic and audio extender cards.
www.24mastering.com
cheers
Misjah
