Japanese Portable Lathes of the 1970s
Steve E.
Site Admin
Re: Retitled: Japanese Portable Lathes of the 1970s
Post: # 29011Unread post Steve E.
Tue Feb 18, 2014 5:06 pm
lucien
Re: Japanese Portable Lathes of the 1970s
Post: # 32957Unread post lucien
Tue Dec 30, 2014 12:19 pm
Here is a nice video of a portable lathe from the 60's :
Snakeheadfishlab
Post: # 33018Unread post Snakeheadfishlab
Sun Jan 04, 2015 11:47 am
That cuts pretty good,where was that built,in the U.S.?
Big Al
Post: # 33063Unread post Big Al
Thu Jan 08, 2015 5:59 am
That's not actually a lathe in the cutting sense, it records onto a disk magnetically similar to tape - no actual cutting at all
and you have to have a special disk that I think can only be played back on this machine or a similar type you can't play the disk on a standard record player using a stylus.
Great sounding machine though - tube electronics and it has two heads one for playback and one for recording which you have to change depending on what you want to do and a separate eraser that wipes the disk when you want to record again!!
emorritt
Post: # 33068Unread post emorritt
Thu Jan 08, 2015 12:47 pm
Yes, it's like a Brush "Mail-A-Voice" but with a pre-grooved disc ala the "Victor Home Recording" discs made of magnetic material. You just don't need the pre-grooved 'guide' disc that the Mail-A-Voice machine uses in this case.
TonyD
Post: # 52030Unread post TonyD
Sat Jan 05, 2019 6:45 pm
Hey folks, I have a matsusho diskll FS it was working then the cutting arm stopped moving, any idea how to fix this problem? I hear the motors turning but it sounds like a gear came off track or something. Any help would be appreciated
discosdecorte
Post: # 56922Unread post discosdecorte
Thu Oct 01, 2020 6:13 pm
Hi there!
I will soon receive a Disk Recorder oll AU70-17-C that seems the same machine as the Matsusho DiskII FS, but I can't find a user manual anywhere! Is there any troll who could please give me some directions on how to use It?
Also, I will need a female connector for this power input: https://preview.ibb.co/mELX1L/91-F99410-27-E7-4619-944-C-9837-FB7-F01-B3.jpg
Any idea on how to Google it (model name...)?
Best regards,
Fer
πŸ„³πŸ„ΈπŸ…‚πŸ„²πŸ„ΎπŸ…‚ πŸ„³πŸ„΄ πŸ„²πŸ„ΎπŸ…πŸ…ƒπŸ„΄
TonyD
Post: # 56923Unread post TonyD
Fri Oct 02, 2020 12:23 am
Depending where you are located you may need a transformer to match the power mains.
discosdecorte
Post: # 56924Unread post discosdecorte
Fri Oct 02, 2020 1:34 am
TonyD wrote: ↑
Hi Tony! I do have the transformer, I was asking only for the model of the two pin female connector I will need to match the power input in the pic, but I think I've found It: https://www.amazon.com/GX20-2-Aviation-Connector-aviation-connector/dp/B06XFCQCFK
Best regards,
Fer
discosdecorte
Post: # 57075Unread post discosdecorte
Tue Oct 27, 2020 3:32 pm
fprado1978 wrote: ↑
Anyone? :cry:
