Sale stylus ruby, sapphire $ 15
alexsation
Post: # 32553Unread post alexsation
Sun Dec 07, 2014 8:46 am
All needle (stylus) is absolutely new. Needle (stylus) were made in Russia during Soviet times, designed for cutting fluorography film and the thin blue film, so-called flexible vinyl discs. Needle (stylus) suitable for most mono cutting heads. Warning: Do not connect the wire heating, necessary to heat the halogen lamp directly recordable disc !!!
Needle (stylus) were not tested, there was no opportunity to do this, you need to experiment!
Postage is fixed 7$ , regardless of the number of needles 1 or 100 pc.
Sale needle (stylus), carried out only through PayPal. If you want to purchase stylus, write to e-mail info@vinylium.ru or private message.
1 needle worth 15$ pc.
Selling on ebey, will be carried out later,
at the moment they do not give sell more than 10 pcs., in a month, I solve this problem.
Best regards, Alexey Sobolev.
http://www.vinylium.ru
http://shop.vinylium.ru
alexsation
Re: Sale stylus ruby, sapphire $ 15
Post: # 32554Unread post alexsation
Sun Dec 07, 2014 8:50 am
:wink:
Self-lather
Post: # 32567Unread post Self-lather
Mon Dec 08, 2014 12:12 pm
Hey Alex/Lathe Trolls, anyone know which one of these might work on a Presto K8?
alexsation
Post: # 32568Unread post alexsation
Mon Dec 08, 2014 12:33 pm
You can use any, but it is better to use №1 or №2. If you have an old the needle, compare the size, it will be more reliable)))
Jccc
Post: # 32569Unread post Jccc
Mon Dec 08, 2014 12:34 pm
Whoa! Pm sent
rsimms3
Post: # 32575Unread post rsimms3
Mon Dec 08, 2014 7:44 pm
I had a great transaction through eBay with alexstation. Ordered two styli November 24th and they arrived December 6th. Tracking in Russia was provided. Styli were well packed and I received what I ordered. I have on older micro sapphire that came with my K10 as well as an old steel needle I'll take a few pics of once I get them all rounded up so folks can see how they compare.
rsimms3
Post: # 32597Unread post rsimms3
Tue Dec 09, 2014 9:21 pm
A few pics (my camera isn't the best). The stylus on the left or bottom is a microgroove that came with my K10, the other two I purchased from alexstation. Definitely look like standard groove styli.
Image Image Image
ROLANDJAYS
Post: # 32599Unread post ROLANDJAYS
Tue Dec 09, 2014 9:53 pm
I wonder if you had a microscope camera, that could take a good picture of the needle....
Someone should make those to sell ... I don't even have one ..
Post: # 32618Unread post tragwag
Wed Dec 10, 2014 4:41 pm
by standard groove do you mean 78 RPM standard groove?
as opposed to microgroove?
interesting...
I bought 2 on ebay, got tracking info that day.
looking forward to getting these
rsimms3
Post: # 32627Unread post rsimms3
Wed Dec 10, 2014 7:37 pm
Yes, that's a must better description. The ones I bought from alexstation are the size of the old steel styli I've been using to practice with recently, 78RPM groove.
Post: # 32642Unread post tragwag
Thu Dec 11, 2014 1:16 pm
rsimms3 wrote:Yes, that's a must better description. The ones I bought from alexstation are the size of the old steel styli I've been using to practice with recently, 78RPM groove.
Whoa!
Thats something else, I don't think I've ever seen standard groove stylus before.
I believe Steve E. was looking for some for a while.
Snakeheadfishlab
Post: # 32686Unread post Snakeheadfishlab
Sun Dec 14, 2014 3:43 pm
Found this for 28$ on eBay,nos sapphire
MBL
Post: # 32694Unread post MBL
Mon Dec 15, 2014 12:24 pm
Which one might be appropriate for a Presto 1-C or 1-D head?
Tim
MBL
klikli_ska
Post: # 32702Unread post klikli_ska
Tue Dec 16, 2014 7:56 am
Keeping on MBL way...Which one might be appropriate for a SC99 head?
Thanks a lot!!
K.
alexsation
Post: # 32703Unread post alexsation
Tue Dec 16, 2014 8:25 am
SC99, this stereo head, she works 320 stylus! all the stylus work only mono cutting heads. Needle must approach to all the Presto head, but better to compare the size of your needles, granted on the size of
photos, it will be more reliable
Post: # 32713Unread post opcode66
Tue Dec 16, 2014 7:35 pm
These styli are not microgroove. So, really, not functional at all for doing anything more than lower quality mono cuts. High frequency information can literally be sliced off by the back angle of this stylus. There is a paper about it in the AES. And, yes, none of these styli have the 1:20 taper required for Neumann, Vinylium, Caruso, Vinyl Recorder or my Project Bladerunner.
Post: # 32738Unread post tragwag
Thu Dec 18, 2014 11:26 am
that all being said, I'm interested to see what they'll do for the embossing/impressing technique.
studiorp
Post: # 32805Unread post studiorp
Sun Dec 21, 2014 4:51 am
Anyone tried number 3 or 4, sapphire or ruby with 1.68mm of diameter ?
gauze
Post: # 32813Unread post gauze
Sun Dec 21, 2014 11:44 am
which style would be recommended for a recordio 6b30 cutting head (astatic x-26)?
