Jccc Modified Presto 6n cutting
Snakeheadfishlab
Re: Jccc Modified Presto 6n cutting
Post: # 30279Unread post Snakeheadfishlab
Fri May 30, 2014 4:23 pm
Thanks
ROLANDJAYS
Post: # 30343Unread post ROLANDJAYS
Wed Jun 04, 2014 12:04 am
nice work and good photos!
Jccc
Post: # 30344Unread post Jccc
Wed Jun 04, 2014 12:28 am
thanks Rolandjays! That feed screw i got from you is working good on the 6n. i can fit so much more music on the disc now compared to what screw i had before which was a 120 lpi. The cool thing is i do not really have to adjust the levels.
Jccc
Post: # 30755Unread post Jccc
Fri Jul 18, 2014 2:55 am
K8 cutting tough
Jccc
Post: # 33760Unread post Jccc
Mon Feb 16, 2015 6:03 pm
ejemmons
Post: # 33770Unread post ejemmons
Tue Feb 17, 2015 2:04 pm
To all you guys - YES!!!!! I truly love the innovation, and courage to try 'stuff'.
RA-1574E amps.
Jccc
Post: # 33782Unread post Jccc
Wed Feb 18, 2015 7:03 pm
here is a example of a lathe cut that was cut on the presto k8 onto plastic plate.
Mpc 1000 > Behringer mixing board to adjust eq > Presto k8
Snakeheadfishlab
Post: # 33796Unread post Snakeheadfishlab
Thu Feb 19, 2015 1:40 pm
Nice,what brand of plates?
Jccc
Post: # 33799Unread post Jccc
Thu Feb 19, 2015 4:42 pm
The brand of plates i use are the ones from Party City. They come in packs of 50 and come in a small range of colors.
Snakeheadfishlab
Post: # 33818Unread post Snakeheadfishlab
Sat Feb 21, 2015 9:50 am
How noisy is the playback?
Jccc
Post: # 33821Unread post Jccc
Sat Feb 21, 2015 11:11 am
Listen to the soundcloud sample i posted to give you a example of how much surface noise is present.
The plate was cut with the presto k8 with 5c cutting head with a old sapphire shank.
For me i kinda like the lofi sound as it goes with my style of music.
Snakeheadfishlab
Post: # 33822Unread post Snakeheadfishlab
Sat Feb 21, 2015 4:31 pm
Yes I love the Lofi,I have a k8.im in the process of formulating some laquer discs,just gotta wait til the weather cooperates.
Jccc
Post: # 45602Unread post Jccc
Mon Jan 16, 2017 12:58 pm
Heres a short clip of a diy lathe cut scratch record i made on a plastic plate.
As you can see in the video it tracks pretty well and the sound is holding up. I think if i make the spindle hole just a bit more small it will prevent the needle from wobbling around.
I am still experimenting!
The record was cut on a Presto K8 with a $7 shank from russia.
https://youtu.be/tPfKhMWw5C8
socialroots
Post: # 45641Unread post socialroots
Thu Jan 19, 2017 6:15 am
Maximum respect Teshun,Ya got finesse!
boom!
Big shout out from my likkle island,
Patrick
p.s finally scored an a shiny chrome Audax, pretty bright top end like you said, and you were right , I had to dial in some low end to bring out the bass.thanks fe di tip.
socialroots
Post: # 45642Unread post socialroots
Thu Jan 19, 2017 6:19 am
Any more to say bout the russian shank? I know youve probably experimented enuff over the last year or so. If its workable for mono lofi then im gonna have to score some, cant beat that price!
How many plates you cutting with one?
respect,
patrick
Jccc
Post: # 45644Unread post Jccc
Thu Jan 19, 2017 10:56 am
socialroots wrote:Any more to say bout the russian shank? I know youve probably experimented enuff over the last year or so. If its workable for mono lofi then im gonna have to score some, cant beat that price!
respect,
patrick
Thanks for the feedback!
As for the shank life, i can cut around 200 7" picnic plates until i notice a decrease in fidelity.
Usually you will here more surface noise in the record and the volume will be lower.
I say for the price its a good deal if your just experimenting.
Jccc
Post: # 46009Unread post Jccc
Tue Feb 07, 2017 8:24 pm
I finally got a proper dash pot for my 6n.
Still dialing in the eq for this Neumann head.
boryo
Post: # 47382Unread post boryo
Thu Jul 20, 2017 3:47 am
Hey, can you post link to those plates? I would like to experiment also but I'm in EU and don't know the USA brands.
nearly215
Post: # 48146Unread post nearly215
Tue Oct 17, 2017 3:39 am
I have a fairchild head like that in my loft always wanted to compare it to the presto 1D that I have but never did and I have not cut anything for about 10 years, was tempted to get rid of all my stuff but I think I will miss it too hard to get hold of .
Jccc
Post: # 48167Unread post Jccc
Thu Oct 19, 2017 1:09 am
I saw you should keep your gear! for me I take breaks on cutting records and always get the itch to make some cuts.
