Acetate Masters.
Acetate Masters.
Hey yall. Wondering if anybody knows how many times I can play back an acetate master before it shows signs of wear.
Re: Acetate Masters.
Once
Correct. You'll get more plays out of it but each time you play it you will wear it further, to the point where you get noticeable distortion and build up of surface noise.
- powerstrip
are you asking for listening's sake or plating/mastering?
dubs can be played back just about as many times as a listener would want - if concentrating on low counterweight - but if you put +6g and a straight-armed tonearm, you can kiss it goodbye real quick...
a lacquer should not be played at all before plating, all testing should have already been done on the outer edge of the disc.
