Meissner 9-1065
takodabut
Meissner 9-1065
Post: # 575Unread post takodabut
Sat Aug 26, 2006 10:21 pm
I just bought a Meissner Model 9-1065 Radio Phono Recorder. It has the operating paper, and an envelope full of needles.
I don't know anything about record cutters. I'm posting to this site only because it came up in a google search on this make and model. My intention in puchasing this unit was to chop it up for guitar amp parts, but that seems like a real shame. Please send me an email at tomp@sandmonk.com if you'd like to buy this thing.
cuttercollector
"chop it up for guitar amp parts"!?!?
Post: # 577Unread post cuttercollector
Sun Aug 27, 2006 5:16 pm
I think I can speak for all here and say PLEASE, PLEASE don't!
It is not an uncommon machine ( I think I have about 5) but what in there is of such value to a guitar amp constructor/rebuilder? Old, out of tolerance leaky wax paper caps and carbon resistors? OK, perhaps, it's old tubes or transformers, but there are other sources for those. As an amp itself it posesses no "magic tone" circuit.
As a disc recording device however, when working properly, it can make a period sounding type of recording, though not HiFi, which is sort of magical in it's own way. A sound which I love.
takodabut
Post: # 580Unread post takodabut
Mon Aug 28, 2006 2:16 pm
OK, I will hold off tearing this thing up. I agree it's sad to destroy things like this, but for the record this thing sounds surprisingly good as an overdriven guitar amp. This leaves me two options with this: 1) replace caps and possibly tubes, then learn to use it, or 2) sell it to someone who knows how to use it.
My hobby budget is already full with other guitar electronics projects and my tube amp storage has already exceeded the wife acceptance level, so does anyone want to buy this? I occasionally drive from my home in NE maine to Rhode Island, and will meet somone at points between. If you happen to be vacationing near Eastport Maine, call me! I don't expect to make a bunch of money on this if I sell it, but it would have to be enough to make it worth meeting or boxing it.
cuttercollector
re turning a disc recorder into a guitar amp.
Post: # 582Unread post cuttercollector
Mon Aug 28, 2006 7:09 pm
At the risk of going entirely off topic, that thing has a single ended 6V6 output I think. So, aside from the radio tubes, the part from the microphone preamp tube through the output should be pretty easy to duplicate. The speaker is neither large nor unusual. I say, use it. Take up a new hobby. It will be fun! Also, did you notice that 2 guests were very interested in another one like yours for sale on this site, should you want to sell it.
takodabut
Post: # 583Unread post takodabut
Mon Aug 28, 2006 7:15 pm
Umm, how hard is it to use one of these?
Is it so simple that I just replace the capacitors, replace and/or bias the tubes, put a normal mike input on the machine, then buy some sort of blank disks? Are the disks expensive?
cuttercollector
actually USING your disc recorder
Post: # 585Unread post cuttercollector
Wed Aug 30, 2006 2:12 pm
Well... It is another one of those analog processes that you can tweak to death unlike our digital brave new world. Yes, basically just buy some blank lacquer discs and a cutting stylus, dial in your cutting angle and depth for a quiet groove, and cut away. you should be able to record from a high impedance unbalanced source like a mic or even a guitar. Or from the built in AM radio. Of course it might need some capacitors or tubes replaced to function normally, but the thing is really not much more than an AM radio chassis with a microphone preamp, a phono playback cartridge and of course the cutter. Other common problem areas are the crystal cutter or playback cartridge not working due to being old and exposed to too much heat or humidity. Also lack of smooth operation of the turntable/lathe mechanism due to old grease and hard rubber drive parts. There are resources for all of this if you poke around this site. My favorites are HRS records for styli and lacuuer discs and West Tech for crystal cutter and rubber idler wheel rebuilding. You probably already know about Antique Radio supply for tubes and caps etc. if you are into guitar amps.
The first time you cut and play a vintage guitar instrumental, you will be hooked! :)
djmeverett
Post: # 595Unread post djmeverett
Thu Sep 07, 2006 6:32 pm
Hi there....I just purchased one of these and I may need some parts if your going to destroy it let me know if you have spare parts youd like to get rid of
