K 8 Tire
Jesus H Chrysler
Re: K 8 Tire
Post: # 35201Unread post Jesus H Chrysler
Sat May 23, 2015 3:03 pm
I recently changed professions and am now a pool and spa repair tech. In the course of my work I've found a pretty good replacement. the housing seal off a pentair challenger pump is really close. it's not as wide but two of them will fit in the groove side by side.
left K-6 platter with pump gaskets, right k-10 platter with stock tire
hope this helps someone.
Also while you're at the pool store, get a tube of aladdin magic lube for lubing the spindle and gears. works better than petroleum jelly.
rsimms3
Re: K 8 Tire
Post: # 35212Unread post rsimms3
Sat May 23, 2015 7:38 pm
That's awesome! I actually looked at something similar back when I had my K10 but never got around to emailing about the specifications on the size. I sort of miss the K10 but my 6N should make up for it once I get it up and running.
Jesus H Chrysler
Re: K 8 Tire
Post: # 35239Unread post Jesus H Chrysler
Mon May 25, 2015 10:49 am
correction, it's the housing seal off a Jandy FloPro pump, not a Challenger.
Jesus H Chrysler
Re: K 8 Tire
Post: # 39441Unread post Jesus H Chrysler
Mon Jan 04, 2016 10:49 pm
correction again. my first post was correct. It is the seal from a pentair Challenger that works. It must be the OEM part and not the Aladdin go-kit part though. pentair p/n 355329
Jccc
Re: K 8 Tire
Post: # 39443Unread post Jccc
Mon Jan 04, 2016 11:27 pm
this is good news! so would i have to get 2 of them for it to work?
the image on your post is not showing up.
Snakeheadfishlab
Re: K 8 Tire
Post: # 39472Unread post Snakeheadfishlab
Wed Jan 06, 2016 10:07 am
Nice, I work for a pool company too,if I need a new tire for my k8 I know where to look.
