Help identify record lathe
Hi!
Who know what is record lathe on a pics?
And how works this lathe? Can i attach this lathe on my Stanton
or other turntable?
or other turntable?
Re: Help identify record lathe
it's RCA overhead
you must to attach an external steper motor with speed controller.
take a look
http://lathetrolls.com/lathetrolls/forum/viewtopic.php?f=1&t=4663
take a look
wraio. mpravo.
Efcharistw Aussie0zborn!
Thank you!Gus wrote:it's RCA overhead
Yes, this is RCA cutter, I thought that this belt turntable system.
I have Stanton T80, after recieved, i try to attach this lathe on my turntable
What do you think about the second lathe, the one that is less ?
i'm sorry but i don't have idea about second lathe
tha standon turntable is not a good choice
i was owner of st-150 4.5 kg/cm and really sucks
I had many problems with the wobble platter
finaly i return it back to the store and tomorrow i will give a try to Reloop RP-7000
Stay Tuned!
Stay Tuned!
- inspector77
You tried the RP-7000? worked better than St-150?
regards
regards
Much better to use a dc motor for pitch. Stepper motors will cause modulation in your grooves. Literally, you'll hear the steps as background noise in unmodulated grooves (grooves cut with no audio).Gus wrote:you must to attach an external steper motor with speed controller.
Yes but with same resultsinspector77 wrote:You tried the RP-7000? worked better than St-150?
regards
the platter of RP-7000 was the same as ST-150
finally i got back the st-150
Right now i'm looking for a modification...
