vinyl recorder with precision motor
marcy108
Re: vinyl recorder with precision motor
Post: # 42838Unread post marcy108
Tue May 31, 2016 5:05 am
i set cutterhead as possible as parallel with earth.please take a look pic.
(i ask to souri about screw.but he still reply me...)
but problem still don't go away....
it' not complete parallel,but i think it can tolerance.how about?
last way is change turntable bearing to new one.
can anyone show other point?
i still need your help.
any help would be appreciated!
best regard,
marcy
sat159p1
Post: # 42843Unread post sat159p1
Tue May 31, 2016 8:15 am
imho, setting "pararell to earth" isn't a good thing. Unless you did the same with your working table, VR table, VR turntable, and VR haevy platter. Then it's OK. If you don't do it, keep it pararell to the platter.
marcy108
Post: # 42845Unread post marcy108
Tue May 31, 2016 11:37 am
hi sat159p1,
thank you for reply.
sorry what mean working table?
anyway also cutterhead holder(sorry,i said "cutterhead" at last post,The correction is "cutterhead holder") is parallel to the platter.
(platter is set parallel to earth.)
what do you say?
i still need help.
any advice would be appreciated!
marcy108
Post: # 42859Unread post marcy108
Wed Jun 01, 2016 12:11 am
i disassembled turntable bearing and clean them.then used oil.
but problem still remain...
i appreciate your continued support!
Gus
Post: # 42867Unread post Gus
Wed Jun 01, 2016 2:16 pm
this is no good thing, i recommend to try with a new spindle.
marcy108
Post: # 42877Unread post marcy108
Thu Jun 02, 2016 12:59 pm
Hi Gus,
Thank you for showing your opinion!
Now I'm waiting new bearing.
I'll post again when I receive it and use it.
Thank you your continued support!
marcy108
Post: # 42897Unread post marcy108
Mon Jun 06, 2016 6:58 am
Hi everybody,
I use new turntable bearing.
Finally my Problem went away!
Groove is stable.I'm so happy!!!
Thank you very much who advice me!!
Marcy
Gus
Post: # 42898Unread post Gus
Mon Jun 06, 2016 10:01 am
marcy108 wrote:Hi everybody,
Marcy
Be careful i think souri didn't calculate his (precision= i'm not sure) platter vs Technics spindle/bearing
That means in the near future maybe will you need again to install a new one Technics spindle/bearing.
It's better to speak with Mike http://www.mikenewaudio.com/bearing.php to find a permanent solution for your problem.
SueDenim
Post: # 42899Unread post SueDenim
Mon Jun 06, 2016 3:38 pm
Hi Marcy,
I'm very happy that you finally managed to resolve your problem!
I consider this thread has vital information for all VR owners so maybe it should be archived for all to discover on a future search.
marcy108
Post: # 42922Unread post marcy108
Thu Jun 09, 2016 2:35 am
Gus wrote:Be careful i think souri didn't calculate his (precision= i'm not sure) platter vs Technics spindle/bearing
thank you for your suggestion.i'll contact him in near future!
SueDenim wrote:I'm very happy that you finally managed to resolve your problem!
thank you,SueDenim!
yes,i hope this thread is useful for other VR users.
in the end,thanks again.
i appreciate you all who help me!
