My DIY Lathe Recorder Project
record cutter 76
Post: # 27360Unread post record cutter 76
Sun Oct 06, 2013 1:37 pm
My old DIY lathe cutter Project that i now should trash
it s a new Construction on the way i send some drawings of the new lathe i should build
Jccc
Re: my diy lhate recorder project
Post: # 27361Unread post Jccc
Sun Oct 06, 2013 6:25 pm
Really cool diy setup! Welcome to the forum and explore.
record cutter 76
Post: # 27362Unread post record cutter 76
Mon Oct 07, 2013 5:01 am
:D thanks i post some more Pictures of my diy lhate
chaosbc
Post: # 27363Unread post chaosbc
Mon Oct 07, 2013 6:38 am
hej ! welcome aboard !
What specificity of your former lathe you want to improve ?
record cutter 76
Post: # 27373Unread post record cutter 76
Tue Oct 08, 2013 7:36 am
:idea: thanks this forum is great, I think!
what I want to change is = remove vibration transfer from the engine through the screw out to arm
and make the arm more stable build a better engraver anytime something like neuman westex just I get blueprints for this stuff etc.
and replace the disc work which for the moment is an English that does not work satisfaing due to numerous layer is worn
it should be replaced with a lenco L75
chaosbc
Post: # 27377Unread post chaosbc
Tue Oct 08, 2013 5:58 pm
wow...neuman like lathe... This is what I call a challenge..
Regarding vibration, have you tried to slice the nut screw in two ? I did that and it improved a bit...
That said I strongly wonder what system is the better : a screw or transmission belt+pulley (like printers)
I am myself in the neverending process of building/rebuilding my diy lathe and so far I used a rod screw + nut screw slided in two.
This evening I saw a guy in the street throwing away a cannon printer I immediately retrieved :mrgreen:
I finished to salvaged it few minutes ago and the pulley/belt system looks really smooth and steady...so I maybe will try to play with it....
record cutter 76
Post: # 27384Unread post record cutter 76
Wed Oct 09, 2013 3:59 am
intresting i have allredy try printers and it can work but i dont like the plastic slade my self but building and rebuilding is the funnyest thing i Think to :D
record cutter 76
Re: My DIY Lathe Recorder Project
Post: # 27403Unread post record cutter 76
Thu Oct 10, 2013 4:37 am
intresting lhate [lathe] cutter you got ther chaosbc !!
great 8)
recordboy
Post: # 27562Unread post recordboy
Wed Oct 30, 2013 7:11 pm
looks good. I too am interested in building a cutter with a two speaker set up.
Your drawings are interesting -too -can't wait to see what becomes of your project.
Are you going to start from scratch and build a new head -or take apart your old one
and use the parts from there?
Cheers,
recordboy
record cutter 76
Post: # 27582Unread post record cutter 76
Mon Nov 04, 2013 6:52 am
thanks for youre intrest in my new diy lahte [lathe] project recordboy .
i whill use mostly new part for my new project
i have started to colect spare parts now before i can start building it
i whill showing some picturs on the way of the building of my new diy lathe and of some of the parts i while use on the way to the compleat diy lathe
pictures while come soon
best regards froam record cutter 76
record cutter 76
Post: # 27853Unread post record cutter 76
Thu Nov 21, 2013 11:30 am
ithings i have baught for my new diy cutter project
record cutter 76
Post: # 27886Unread post record cutter 76
Sat Nov 23, 2013 10:39 am
more image photos of things i goot to the new diy lathe cutter projekt
now it is only some Wood parts left befor i can start to build etc a turnplatter made in thick 60 cm gerth
42 cm wide . a new motor whithe gear box to drive the scruve
and a microscoop etc
recordboy
Post: # 27941Unread post recordboy
Wed Nov 27, 2013 12:05 pm
:shock: looking forward to seeing more... !
Cheers,
recordboy
record cutter 76
Post: # 28453Unread post record cutter 76
Thu Jan 09, 2014 11:16 am
a verry good book that im soon have !!! cant wait for it :P
and a rec o kut turntable for my projekt
record cutter 76
Post: # 29050Unread post record cutter 76
Thu Feb 20, 2014 10:34 am
hope that some wone can tipp me of a great pair of speakers that i can use as cutter head
or if ther is some one that have a old mono cuting head for sale i would love to buy it
best regards froam michael
record cutter 76
Post: # 29134Unread post record cutter 76
Thu Feb 27, 2014 2:11 pm
some improvments on my old diy cutter
record cutter 76
Post: # 29135Unread post record cutter 76
Thu Feb 27, 2014 2:15 pm
more pictures
record cutter 76
Post: # 29180Unread post record cutter 76
Wed Mar 05, 2014 12:38 pm
some more things to my new lahte cutter projekt one electric power suplye for the dimond whithe difrent volt and amp you can control the heat wire preaty good and the second thing was a electric 230 to 110 transformer for the rec o kut motor
record cutter 76
Post: # 29493Unread post record cutter 76
Sun Mar 30, 2014 3:29 pm
new pctures of my new Project lahte
record cutter 76
Post: # 29494Unread post record cutter 76
Sun Mar 30, 2014 3:36 pm
this maschine whil be better and hard to transport when its done
