rek-o-kut 110v voltage conversion
graph
Post: # 28338Unread post graph
Fri Jan 03, 2014 9:15 pm
hi guys,
just wondering if theres any advice on changing the voltage with a 110v rek-o-kut for use in the u.k.
i've read that using a convertor will also change the frequency but this means the rek-o-kut spins slower.
how would you solve that issue?
cheers
Stevie342000
Re: rek-o-kut 110v voltage conversion
Post: # 28339Unread post Stevie342000
Sat Jan 04, 2014 4:23 am
Yes there may be a way found this on eBay http://www.ebay.co.uk/itm/Russco-Bodine-Broadcast-Turntable-2-Speed-50-Hz-Capstan-/221275019804?pt=Vintage_Electronics_R2&hash=item338504da1c
Its a capstan sleeve which may fit on the Rek-O-Kut motor shaft or
You could buy the motor and shaft the motor can be found here:
http://www.ebay.co.uk/itm/221215238200?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Maybe seem pricey but it may be the cheapest alternative there is a 3 speed 50Hz capstan sleeve as well.
graph
Post: # 28343Unread post graph
Sat Jan 04, 2014 11:52 am
hi steve, thanks again for the info.
i found this thread here on lathe trolls: https://www.lathetrolls.com/viewtopic.php?f=1&t=995&hilit=rek+o+kut+50hz
if you scroll down you see simon mention something about using a car dc 12v with a 30amp regulated power supply.
i dont know what those bits are or if they could work?
cheers
Stevie342000
Post: # 28349Unread post Stevie342000
Sat Jan 04, 2014 5:04 pm
Yes I knew it had been mentioned before but short of searching thread or topics to find it thought it was easier to mention it again.
The easiest way is to change capstan motor pulley or change the motor, you would need to check that the inner diameter of the capstan pulley was the same diameter of the motor you have already. Which means you would not need to change the motor just change the capstan shaft or pulley to a 2 or 3 step one.
Oh yes assume you know this already you need a 240v to 110v step down transformer.
Jobs a good one, going in the other route you could use an inverter but they tend to be expensive and the sine wave is not all that good.
Hope that helps, the inverter route is not the easiest or cheapest route.
Gus
Post: # 28350Unread post Gus
Sat Jan 04, 2014 5:20 pm
Here is another method if you know some electronics
http://lhchangaudio.blogspot.gr/2011/07/turntable-power-supply.html
http://www.lencoheaven.net/forum/index.php?topic=5982.270
I have already built Altman's speed controller and works fine :D
http://www.altmann.haan.de/turntable/
graph
Post: # 28351Unread post graph
Sat Jan 04, 2014 6:33 pm
nice one guys, very helpful indeed. thank you
i dont own the rek-o-kut but i've had my eye on the one which is in the classifieds at the moment. i'm trying to gauge what it will entail to get it working properly if i did come to own it. if i knew i could somehow get it spinning at the correct speeds that would be cool, no worries. i guess i'd just like to know for sure before buying that it should work out fine. the last thing i want is to end up with something that may cause me a huge (potentially expensive) headache to begin with.
cheers
Stevie342000
Post: # 28353Unread post Stevie342000
Sat Jan 04, 2014 7:51 pm
I had a look at the Lenco heaven Speed controller it's the way to go but there are no pcbs available right now.
You can build either a 50Hz or 60Hz version all 3 speeds are catered for.
It took awhile to download all the schematics, instructions and to read the 15 pages of threads there are a couple of threads by Nigel.
Really neat and professional job no bare anything to touch even when making internal adjustments.
You will find the pcb section in members only market place and group buys.
It would certainly be the route to go for you and for me. Now we just need to get our hands on the pcb not sure how many is in a set but its like only £4 they're FR4. From the comments everyone is pleased with them.
The design is a variable oscillator, power amp and a step up transformer.
Gus
Post: # 28356Unread post Gus
Sun Jan 05, 2014 6:16 am
The theory for a DIY inverter (2 phase motor variable speed controller), is to use mp3 track of 60 Hz, in stereo, 90° out of phase.Run the signal to a stereo amp class D . Then through a output speakers to 12 volt - 110 volt transformers and out to the turntable motor. turn up the volume until to see the motor spins. :D
http://www.ebay.com/itm/Nuvotem-Talema-Toroidal-Transformer-Pri-110v-Sec-12-0-12v-24vct-Tests-Good-/221341021204?pt=BI_Circuit_Breakers_Transformers&hash=item3388f3f414
mp3 player----->stereo amp class D------>12v to 110v transformers-----> turntable motor
i have allready built this for a stepper motor and runs very smoothly like a AC synchronus motor
mp3 player---->stereo amp class D----->stepper motor
here is what i used for a stereo amp
http://www.ebay.com/itm/321089161610?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Gus
Post: # 28357Unread post Gus
Sun Jan 05, 2014 6:44 am
mp3 or Wav file of 60hz Sine wave :wink:
Stevie342000
Post: # 28358Unread post Stevie342000
Sun Jan 05, 2014 7:33 am
That would work for Graph but would not work for me who is stuck with the standard motor speed of 33 1/3 rpm and no capstan sleeves for 45 rpm & 78 rpm.
However you could use a signal generator to drive the amplifier which in turn drives the D class power amp and then the 12 v to 110V (230V) step up transformer.
There is more than one way to go about it I like the Lenco circuit it would work for me on my Sugden Cutting Lathe.
But would go the other route to drive for example my Garrard 401, there is mileage in running it at 110V you get less rumble.
Incidentally I am on the list for one of the spare PCBs for the Lenco Speed Controller, this is certainly a project many of us could benefit from as far as motor speed control goes.
You could probably modify it to drive a motor for groove pitch. The method of signal gen, power amp and transformer would work except driven by an advance head from a tape machine or other source through a high or mid cut filter network. As it is the bass region you need to be concerned with.
graph
Post: # 28359Unread post graph
Sun Jan 05, 2014 7:46 am
yo guys,
yh i joined up on lenco an read up a bit on whats what with the controller thing etc. that seems a fairly straight forward way of sorting out the speed issue, i think thats not too out of my depth. but would simons solution work out just as well and cost about the same?
anyway would there be any chance that i could get on the pcb list?
cheers
Gus
Post: # 28360Unread post Gus
Sun Jan 05, 2014 9:26 am
Stevie342000 wrote:That would work for Graph but would not work for me who is stuck with the standard motor speed of 33 1/3 rpm and no capstan sleeves for 45 rpm & 78 rpm.
Hey stevie if with 60hz sine wave file your motor spins right @ 33.3 rpm then with 78hz (for example) sine wave file your motor should be spins @ 45 rpm and with 30 hz sine wave file should be spins @ 16 rpm.
you must to make measurements with a digital tachometer http://www.ebay.com/itm/LCD-Digital-Laser-Photo-Tachometer-RPM-Non-Contact-Tach-Motor-Speed-Meter-New-/251155886670?pt=AU_Car_Parts_Accessories&hash=item3a7a0eb24e&vxp=mtr to find the correct speeds.
Stevie342000
Post: # 28362Unread post Stevie342000
Sun Jan 05, 2014 10:07 am
Thanks Gus that would work fine only my machine is not running slow as it runs on 50hz but is missing the capstan sleeves for 45 rpm & 78 rpm. 16 2/3 rpm might be an option as would 22.5 Hz for trying out half speed mastering.
I suppose I could do the maths to work out what frequencies I would need but would you be so kind? I would hate to get it wrong.
I have a Heathkit AG-10 needs repair but by the time I fiddled around getting that up and running with a power amp and transformer it would probably work out more expensive. It might work nicely as a variable speed controller for a tape deck.
On the Lenco forum for the Variable Speed Controller it is advised not to run a 50 Hz motor (or least with his design) below that figure or below 30Hz. You would have to read all 15 pages to find exactly what the issue was, probably to do with AC synchronous motor and cogging (a problem with Papst motors).
There are always options with any circuit or design, personally I think I prefer the Lenco Variable Speed Controller.
But on the other hand the mp3 or variable oscillator (signal generator - you could make a tape loop or mp3 loop and copy frequencies to a cd - you could probably find an online sine wave signal generator these days) and drive a power amp with step up transformer
Both have merits or another option would be to bypass the signal generator in the Lenco design & feed it with the right frequency on a loop from a cd player.
Stevie342000
Post: # 28364Unread post Stevie342000
Sun Jan 05, 2014 10:24 am
Just did a simple search and found this online signal generator which you can download for free http://heliso.tripod.com/download/generator/dsg.htm
Its RAR file you may need Winzip.rar or equivlant just download that as well from net.
There you go signal generation sorted out.
Gus
Post: # 28365Unread post Gus
Sun Jan 05, 2014 10:41 am
Stevie342000 wrote:Thanks Gus that would work fine only my machine is not running slow as it runs on 50hz but is missing the capstan sleeves for 45 rpm & 78 rpm. 16 2/3 rpm might be an option as would 22.5 Hz for trying out half speed mastering.
you can create sine wave files with audacity and extract them to an iphone,mp3 player whatever. 30-35 minutes file is enough for every side of vinyl record.
also i have create my own (90 degrees out of phase) phase-shifter plug in for Audacity, if you are interesting send me a pm and i will send it you for free.
http://teribil-audio.com/2012/05/mp3-player-turntable-drive/
Stevie342000
Post: # 28366Unread post Stevie342000
Sun Jan 05, 2014 12:02 pm
Thanks Again Gus
Shows how much I use Audacity I have Sony Sound Forge on this computer as well, suspect that will have tones for setting system levels as well.
Will check it out, there are several online signal generator as well, the first one is either not so good or I am useless at getting it to work efficiently or correctly.
This webpage is useful for test tones http://www.audiocheck.net/audiofrequencysignalgenerator_index.php
Gus
Post: # 28367Unread post Gus
Sun Jan 05, 2014 1:17 pm
Stevie342000
Post: # 28368Unread post Stevie342000
Sun Jan 05, 2014 1:30 pm
Neato
So in affect you could use this to drive a second motor to automatically do run-in, Separation and lead-out groove.
By changing the frequency you change the speed the motor turns at, on my deck is like 1/3 of turn for separation groove, one or two turns for lead in or faster (off the top of my head and memory) for lead out, it was probably slower and more turns.
Well got to run get a job application deadline to meet.
